What is your winter project?
GregLawlerMinn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GregLawlerMinn Quote  Post ReplyReply Direct Link To This Post Topic: What is your winter project?
    Posted: 12 Dec 2010 at 9:17am
Mine is a rehab of the CA that I have been using for the past 4 years as a lawn mower (it has a Woods L306 belly mower). The tin is all off it and the bare frame is in for sandblasting and painting. When it comes back, it will be time to pull the rear wheels and finals to replace the brakes (including a new drum on the left side...and maybe rebuild the drum on the hand clutch), rebuild the hand clutch, new pinion seals and clean/relube the final pans (as well as inspecting and rebuilding the final bearings and the hand clutch actuator as necessary. The rear rims will be sandblasted and painted (and the eccentrics cleaned/lubed with antiseize) while I'm doing the finals. Then it will be on to the front of the tractor to install a new engine clutch, replace the front axle (it currently has a C wide front axle), rebuild the front axle pivot, and new frfont axle bearings. Will also open the engine and inspect it (altho it starts and runs fine; want to check the sleeves, pistons, journals, plastigage/reshim the bearings, and inspect the head and valves). Then on to the outer parts; replace the gages, new 12 volt electrical, replace the Farmall distributor with an Allis distributor and EI, and new head lights. Meanwhile, the tin will be at the body man for prep and paint. If all goes well, expect to have it running well by the time the body man is done with the tin. Finally, install the tin, lights, decals and have it ready to resume her regular job when the grass is green and growing.
michaelwis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote michaelwis Quote  Post ReplyReply Direct Link To This Post Posted: 12 Dec 2010 at 9:19am
Shoveling snow .. and going to Pasadena..then shovel more snow upon my return
WD WD45 DIESEL D 14 D-15 SERIES 2 190XT TERRA TIGER ac allcrop 60   GLEANER F 6060 7040.and attachments for all Proud to be an active farmer
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 12 Dec 2010 at 9:26am
Blowing snow here too ! Flywheelers GOTO, Working on new silo construction shop  across the road at daughter and son-in-laws farm (they took over the business) so my shop is freed up for A-C projects. Swap engine from 220 into 210. Build 220 into heavy duty heavy tillage beast (3500 MK II engine with factory inline pump add intercooler, Mexican hat duals etc.etc. So many projects and not enough time.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TedBuiskerN.IL. Quote  Post ReplyReply Direct Link To This Post Posted: 12 Dec 2010 at 11:20am
D17 diesel , D14 overhaul, Florida AC Jamboree GOTO at the Flywheelers. And a WD leak repair.
Brian S(NY) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian S(NY) Quote  Post ReplyReply Direct Link To This Post Posted: 12 Dec 2010 at 11:24am
ac 616, nice original, starts runs, drives, doesnt charge, wont start on key, : manure spreader Im converting to trailer: etc etc etc
JohnThomas View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnThomas Quote  Post ReplyReply Direct Link To This Post Posted: 12 Dec 2010 at 11:38am
Building my wife a brand new Hickory kitchen complete with modern appliances. Hopefully Will install by March if these PCa treatments don't bog me down too much..
Snow dumping on us big time here now. Up to my knees by 0945.
Life is short...Make haste to be kind
Don(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 12 Dec 2010 at 12:17pm
Putting a Mounted corn picker model 33 on a 1949 WD.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ChuckLuedtkeSEWI Quote  Post ReplyReply Direct Link To This Post Posted: 12 Dec 2010 at 12:45pm
Before I can get to my winter projects, I got to finish my fall projects!!  One was putting the loader I bought on my D17 IV.   I finally got all the brackets on, now all I have to do is throw the wide front on and then hook up the loader.   Once that's out of the garage, I have an unstyled WC I want to get running again, and then work on what else it all needs, and a D19 that needs a clutch and then who knows what else after that.   Got two wiring harnesses sitting on the shelf for my D15 and my B that hopefully will get installed this winter.
mlpankey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 12 Dec 2010 at 12:47pm
wishing it would snow so deep that it covered up my projects so I didnt see them for  while. Its easier to start 3 projects than to complete 1.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 12 Dec 2010 at 12:57pm
I need to clean up my shop so I have a place to work and can get to the wood stove so I can have some heat. The CA has been patiently waiting(for 3 years) my attention with a bad thrust bearing . I want to build some high display shelves to put the tools and things that came from Dad's garage.
Oldoug View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Oldoug Quote  Post ReplyReply Direct Link To This Post Posted: 12 Dec 2010 at 1:03pm
Save money to build a shed.
Matt Folkers
FOLKERS RESTORATION
Stan IL&TN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan IL&TN Quote  Post ReplyReply Direct Link To This Post Posted: 12 Dec 2010 at 1:09pm
My F40.  Plan to start on the tins after Christmas.  Wheels maybe next then rest of tractor.  Last weekend I bought a 32 gallon compressor for the painting and wired it up yesterday.  Wife is getting me a paint gun for my Christmas then the fun will begin.
1957 WD45 dad's first AC
1968 one-seventy
1956 F40 Ferguson
AdamA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AdamA Quote  Post ReplyReply Direct Link To This Post Posted: 12 Dec 2010 at 1:16pm
Finish up a room addition,wheel weights on the 7040,new cab kit for the 8030,and overhaul the 185
Edited by AdamA - 14 Dec 2010 at 9:57pm
57'D-17,78'185,83'6080,76'7040,84'8030 FWA.02'Dodge cummins
E7018 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote E7018 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Dec 2010 at 1:24pm
A 301 engine in D17. I have the clutch housing buttoned up, starting on the frame rails to put front wheels on. No unsolvable problems yet.;)
Thad in AR. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Posted: 12 Dec 2010 at 2:22pm
'38 unstyled wc. I'm building one set of fenders out of two and I've got all the welding done now they need blasted and painted. I've also got a g basket case that I'll work on as I find parts. So far it's in one piece  minus the motor and rear wheels/tires. I cant wait to find 2 real nice used rear tires and tubes for cheap. HA HA lol.
morton(pa) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote morton(pa) Quote  Post ReplyReply Direct Link To This Post Posted: 12 Dec 2010 at 2:27pm
1985 Jeep CJ-7. Lifting around 4 inches and replacing the body tub, painting, and bedlining the interior and underside. Hope to get it done in January but things have been slow to take effect so it might not get done until after that.
Fred in Pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 12 Dec 2010 at 2:40pm
No Winter PROJECTs ,just finsh what was started before winter. I have Harvey ( all joke's  aside )coming to paint the new show room,being that is all he done his whole life with a Family business.Then it will be getting everything in and set up .Been backed up with shop work ,need to get cault up with it .That is what makes my Money.Been ask 2 times to go to Flywheeler show with Woody ,but it is also not going to happen TOO much with other things going on.Bottom line just get things done befor spring.
Post Options Post Options   Thanks (0) Thanks(0)   Quote morton(pa) Quote  Post ReplyReply Direct Link To This Post Posted: 12 Dec 2010 at 2:46pm
Fred let me know if you need any help with the showroom between now and January 17th...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 12 Dec 2010 at 2:47pm
Hope the bath room and heat will be in, in the next week.Then Harvey can start.Never put anything in a buildsing until you arer completly done with building ,covering and moving things are a PITA!   LOL !
JH Buck View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JH Buck Quote  Post ReplyReply Direct Link To This Post Posted: 12 Dec 2010 at 2:51pm
Getting ready for an auction in the spring hope to get rid of a bunch of Antiques stuff I have collected over the last 50 + years.
jb from md View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jb from md Quote  Post ReplyReply Direct Link To This Post Posted: 12 Dec 2010 at 5:04pm
not much a-c action this winter. right now its my parents 62 ford galaxie convertible. this is an old pic. its painted now and we are putting it back together. we will be putting brakes on the 185...Jb
8050 FWA, 190XT, 185, Styled wc, Unstyled wc, (2)C, (2)WD45NF, WD45WF, WD,416h, 716h, 312h, 8070 pedal.
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 12 Dec 2010 at 5:10pm
been burning leaves since thursday morning looks like its turned into aother winter project. 67 camaro painted needs completed .  H johndeere needs completed CA allis needs painted D15 allis needs oil change and painted . Pulling tractor always needs something
Edited by mlpankey - 12 Dec 2010 at 5:12pm
rob(ont) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rob(ont) Quote  Post ReplyReply Direct Link To This Post Posted: 12 Dec 2010 at 5:11pm
Putting a new boiler under a 1916 George White 25hp side mount traction engine. Why do I get myself into these things? Need some heat in the shop too.
tractorchuckie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tractorchuckie Quote  Post ReplyReply Direct Link To This Post Posted: 12 Dec 2010 at 5:41pm
I will be hoping to get the 20-35 running and to get an good jump or done the model A . thxchuck
still looking for the holy grail of Allis
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 12 Dec 2010 at 5:51pm
Maintaining my sanity until Spring!! when I can get back out to play in the dirt!
cbuttre835 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cbuttre835 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Dec 2010 at 5:59pm
mine: closing in my attached garage, making an office, laundry room, and familiy room.
Allis - related:  watching / assisting my dad in getting his WD-45 running.  Swapping the NF out of it for a WF.  Getting his 3 bottom plow put back together as part of that project too.  He's gonna break ground with it this spring, he says.  wish us luck.
C w/ 3rd gear out
D15 II factory 3 point
WD (no motor!)(parts for sale!)
WD 45 wide front
GARY(OH/IN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GARY(OH/IN) Quote  Post ReplyReply Direct Link To This Post Posted: 12 Dec 2010 at 6:33pm
Pulling and rebuilding the 283 in my wife's '64 Chevy Impala Convertible. Pulling the transmission and having it rebuilt. Front tranny seal leaking, think it's from various mount bushings being bad as engine doen't even look right setting in there.
Replace wiper motor and find brake leak on 1978 Chevrolet 1 ton dump truck. Does anyone have a wiper motor? Don't use it a whole lot but have a few things I need it for.
Remodel the living room in a lake cottage. Then in the spring it gets a new roof and an 8 x 24 deck then a for sale sign.
Ken in Texas View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ken in Texas Quote  Post ReplyReply Direct Link To This Post Posted: 12 Dec 2010 at 6:58pm
The three Cs. Catch, Clean and Cook all the Texas winter trout I can take time to fish for. 278,895 stocked statewide. 16,500 close to home.
Jeff-in-Kunkletown View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff-in-Kunkletown Quote  Post ReplyReply Direct Link To This Post Posted: 12 Dec 2010 at 7:10pm
Finally getting back to my B that I started last year.
Sucess is how high you bounce after hitting bottom. Gen. George S. Patton
TREVMAN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TREVMAN Quote  Post ReplyReply Direct Link To This Post Posted: 12 Dec 2010 at 7:43pm
Vapor barrier, SOB my shop, get the furnace line in, paint the walls, organize the "merchandise" work alternatively on my ALLIS 720 (paint, decals, a bit of wiring to resolve) a 1946 chevy 2 ton(brakes,king pins,body work,wiring,front tires,etc.), and my Mercury 402 outboard/1976 glastron 14.5 boat(seats, paint, decals, general rehab) and try to meet some of my wifes various and sundry requirements... Not likely to get through 20% of the above named...TREV.
