WD hydraulic ram leaking
Don(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MI) Quote  Post ReplyReply Direct Link To This Post Topic: WD hydraulic ram leaking
    Posted: 11 Dec 2010 at 6:50pm
Hey all, put oil in the WD the other night and noticed that I have one ram leaking more than I would like it to.
What are the pointers on repairing rams? I have never tackled this, are there a couple seals to replace? Thanks, Don
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 11 Dec 2010 at 7:40pm
Try tightening the packing a little first. If the nut is bottomed out you will need packings. Just don't over tighten. These packings have to let a very small amount of oil through to keep themselves lubricated.
Dave A View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave A Quote  Post ReplyReply Direct Link To This Post Posted: 11 Dec 2010 at 8:28pm
If it is a AC loader turn the packing gland on the top of the cylinder down a little and it should stop. They need to leak a little like CTucker is saying. If the packing will not tighten any more they will need to be replaced. The packing shouldn't cost much and once you start taking things a part you will see how they work.
Play the game for more than you can afford to lose... only then will you learn the game.
Winston Churchill
This page was generated in 0.476 seconds.
