Allis B's with Snowplows
morton(pa) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote morton(pa) Quote  Post ReplyReply Direct Link To This Post Topic: Allis B's with Snowplows
    Posted: 10 Dec 2010 at 10:57am
Anybody have one? I know theres lots of home made ones out there with lots of different styles and designs. Anybody have any pictures or ideas I could use to build one? Any designs I should avoid because of flaws?
Bill Long View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Long Quote  Post ReplyReply Direct Link To This Post Posted: 10 Dec 2010 at 11:18am
We did not make snow plows for the B.  We used the Myers Snow plows.  They did an outstanding job and were well made and framed.
There may be pictures of them available or you may be able to obtain one from Myers.
Thinking, I recall one made with a plank on a cultivator frame mid mounted.
Simple set up and worked OK.
Take good care of my favorate.
Good Luck!
Bill Long
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 10 Dec 2010 at 12:09pm
B26240 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote B26240 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Dec 2010 at 2:45pm
Morton if you build your own I suggest long push arms from plow to the drawbar, pushing from drawbar is the strongest point and gives a parralel to the ground angle HTH -- Mark
brent-pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote brent-pa Quote  Post ReplyReply Direct Link To This Post Posted: 10 Dec 2010 at 4:58pm
Morton,
Where in PA are you located- we have two C's and a B with snow plows on them your welcome to come look at, I don't have any pics.
 I push from the drawbar on the C's and the B I push from the moldboard plow brackets on th final drives.
Brent-PA
Edited by brent-pa - 10 Dec 2010 at 5:03pm
D17,D15,WD45,(2)WC's,(4)CA's,(4)C's,(4)B's,G,616
Chris/CT View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris/CT Quote  Post ReplyReply Direct Link To This Post Posted: 10 Dec 2010 at 5:52pm
I have a reprint of the snowplows if you would like it.
tomdavison View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tomdavison Quote  Post ReplyReply Direct Link To This Post Posted: 10 Dec 2010 at 6:07pm
Mine is home made and came with the tractor when I purchased it.  It is on a 1953 B with the adjustabe fron axle.  The plow pushes from the mounted plow drawbar with two pursh bars.  There are two pulleys for cable mounted on each side of the front axle.  Cables run from the plow, up over the two pulleyss and back under the tractor to a pulley on the main drawbar, and from the pulley up to the lifting bracket for the right hand mounted plow.  I jave  modified it some so that I can use two cylinders tor raise it.  It workds good.  The angle of the plow for cutting can be changed with the plow depth control lever.  The plow angle cannot be changed.   Works very good.
AC WD45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC WD45 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Dec 2010 at 6:37pm
German Shepherd dad
1957 Allis Chalmers WD45
#WD234847
1951 Allis Chalmers WD
#WD88193
BrettPhillips View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrettPhillips Quote  Post ReplyReply Direct Link To This Post Posted: 10 Dec 2010 at 6:53pm
I have what I believe to be a Myers snow plow mounted on my '49 B.  When I got it the mounts were badly hacked up, so I used them as patterns as best I could and made new mounts for it.  I will try to get some pictures of it tomorrow.  I have thought of drawing up the mounts in CAD at work, then offering PDF plans packages for $10 or so.  The plans would only be for the mounts, as a 6 ft Myers manual angle Jeep blade would probably be a drop in fit.  Is there any interest?
Rick of HopeIN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick of HopeIN Quote  Post ReplyReply Direct Link To This Post Posted: 10 Dec 2010 at 7:04pm
for sure I have seen IBs with nice plow setups off the front frame.
Mark in Iowa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mark in Iowa Quote  Post ReplyReply Direct Link To This Post Posted: 10 Dec 2010 at 9:21pm
Brett, I would be interested in seeing the pictures/plans. thanks, Mark
swit View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote swit Quote  Post ReplyReply Direct Link To This Post Posted: 11 Dec 2010 at 5:47am
mine has a 7ft plow on it I bought it like this who ever made it did a super job it has one cylinder.frame mounts to draw bar and up front using front end frame. wheels on both ends of plow so i dont push my gravel works  well let me know if you want pics i will have to go take some but no big deal i can handle that.the only down fall of it is that fully raised it is only about 9 inches from the ground even that hasnt caused me any problems
firebrick43 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote firebrick43 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Dec 2010 at 2:35pm
JohnCinMd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnCinMd Quote  Post ReplyReply Direct Link To This Post Posted: 11 Dec 2010 at 8:06pm
Here's one on Craig's List....
Post Options Post Options   Thanks (0) Thanks(0)   Quote morton(pa) Quote  Post ReplyReply Direct Link To This Post Posted: 12 Dec 2010 at 2:39pm
Yup I've seen Rod's website before. Never got around to making that style though and I was thinking of making something with a pulley system that goes to the rear lift. I've seen that used somewhere before and it would use a lot less material which would be great.
This page was generated in 0.056 seconds.
