WD rim stops
Don(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MI) Quote  Post ReplyReply Direct Link To This Post Topic: WD rim stops
    Posted: 09 Dec 2010 at 6:34pm
Is it nessecary to have 2 rim stops per rim bolted to the rail, one on each side of the hub? The WD has two on one side, and one on the other side. Just wondering what came stock and what I need. Thanks, Don
Gary in da UP View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary in da UP Quote  Post ReplyReply Direct Link To This Post Posted: 09 Dec 2010 at 6:41pm
I think that they  only came from the factory for forward rotation stops, but maybe Bill Long, or one of the more experienced forum members knows for sure.
R Aiken View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote R Aiken Quote  Post ReplyReply Direct Link To This Post Posted: 09 Dec 2010 at 6:57pm
Our 45 and 17 had 2 stops on eavh wheel.  All the way in or out you just need one, but inbetween you need a stop on each side. One for forward and reverse.
HagerAC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HagerAC Quote  Post ReplyReply Direct Link To This Post Posted: 09 Dec 2010 at 7:11pm
Yeah there should be 2, but only one is needed when they are all the way in, or all the way out.
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Dec 2010 at 7:18pm
Like the guys said above two per side. if you use just one and the wheel moves boy you will know it! BANG!!!!!!! I learned the hard way doing some blading one time.
Don
BILLP-SE-MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BILLP-SE-MI Quote  Post ReplyReply Direct Link To This Post Posted: 09 Dec 2010 at 8:01pm
Hey Don nice WD, ya you need two for each Rim. One more Orange project in the works I see. That picker set up on the WD will be nice. If ya need any info just give a call.
Have a good one.    Bill P
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Dec 2010 at 5:11am
Thanks Bill!
I might just set the tires all the way out, and use one rim stop per rim. Already broke one, those little buggers FREEZE up tight with rust.
Also, looking for one good rim, and one good 14.9 x 28 tire as well.
thanks, Don
pumpkin man View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote pumpkin man Quote  Post ReplyReply Direct Link To This Post Posted: 10 Dec 2010 at 5:20am
    Don  - Bill  is changing his hndl . to  SHEENEY Bill
Brian F(IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian F(IL) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Dec 2010 at 8:03am
If you need some, I just got some new stops from Tony C. earlier this year.
