All-Crop Hub/Axle ??
TomYaz View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomYaz Quote  Post ReplyReply Direct Link To This Post Topic: All-Crop Hub/Axle ??
    Posted: 09 Dec 2010 at 6:01pm
Ok, prepping the wheel axle for reinstallation.  One side of these axles got more wear than the other...Not sure which side it was.. the top of the axle or the bottom.
In looking at pics I took prior, it looks like the bottom of the axle(side closer to the ground) got the most wear.  Im no engineer but seems counterintuitive to me...Reason Im asking is I want to flip the axle so that the good side gets the new wear.
NCAllisnut View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NCAllisnut Quote  Post ReplyReply Direct Link To This Post Posted: 09 Dec 2010 at 6:22pm
The axle is pressing down in the wheel right?  So the axle would wear on the bottom side?
Adam
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomYaz Quote  Post ReplyReply Direct Link To This Post Posted: 09 Dec 2010 at 6:47pm
Adam
Yes your right. My warped thinking had the weight of the machine on top of the axle.---wow I should NEVER become an engineer......
R Aiken View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote R Aiken Quote  Post ReplyReply Direct Link To This Post Posted: 09 Dec 2010 at 6:52pm
Adam
the same thing with a tire they go flat on the bottom
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomYaz Quote  Post ReplyReply Direct Link To This Post Posted: 09 Dec 2010 at 7:24pm
Adam
And to think I am a computer programmer...you know..Im supposed to think logically....
Maybe thats why when I took a computerized career survey in Vo-Tech school the computer said I should consider being a "photographers model". It seemed funny at the time....
Edited by TomYaz - 09 Dec 2010 at 7:24pm
norm[ind] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm[ind] Quote  Post ReplyReply Direct Link To This Post Posted: 09 Dec 2010 at 7:49pm
   did you ever trhink of marking before taking it apart???????????  will go bac k together easier
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomYaz Quote  Post ReplyReply Direct Link To This Post Posted: 09 Dec 2010 at 8:01pm
Originally posted by norm[ind norm[ind wrote:
]   did you ever trhink of marking before taking it apart???????????  will go bac k together easier
Obviously not.
Rawleigh View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rawleigh Quote  Post ReplyReply Direct Link To This Post Posted: 10 Dec 2010 at 10:56am
Tom:  I flipped mine and it worked fine.  Almost like a new axle as long as weight is on it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomYaz Quote  Post ReplyReply Direct Link To This Post Posted: 10 Dec 2010 at 11:48am
Yep got the idea from you. Know it will work, just couldnt recall what side to flip.
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 10 Dec 2010 at 12:12pm
It's not just you Tom, I had the same type of brain farts before and I won the MN state PAS mechanics high individual contest in 91 and 92.
Wink
I am a Russian Bot
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomYaz Quote  Post ReplyReply Direct Link To This Post Posted: 10 Dec 2010 at 12:51pm
Glad Im not the only one...They just seem to happen more frequently as I get older...I need gas-x for the brain...
