All-Crop Part Needed
TomYaz View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomYaz Quote  Post ReplyReply Direct Link To This Post Topic: All-Crop Part Needed
    Posted: 09 Dec 2010 at 8:15am
Folks,
Need a gear 500529, or good used. Goes on the unloading auger.
GlenninPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GlenninPA Quote  Post ReplyReply Direct Link To This Post Posted: 09 Dec 2010 at 9:23am
Hmmmm..... That number sounds familiar. Let me look in my box of All Crop NOS.
Post Options Post Options   Thanks (0) Thanks(0)   Quote GlenninPA Quote  Post ReplyReply Direct Link To This Post Posted: 09 Dec 2010 at 9:26am
Sorry, nope... Got gears, but not that one.....
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomYaz Quote  Post ReplyReply Direct Link To This Post Posted: 09 Dec 2010 at 9:52am
Im crestfallen!
Reason I need it is I need to take the existing gear off the auger so I can rebuild the auger boot.  Cant get it off!! A gear puller I use wont work; the claws cant bite on to the backside of the gear.  My fab man couldnt get it off either (and if he cant, I know its not "just me").  So we have little choice but to grind/burn it off..
Joe Graunke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe Graunke Quote  Post ReplyReply Direct Link To This Post Posted: 09 Dec 2010 at 12:02pm
I'll check my nos parts
Joe
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomYaz Quote  Post ReplyReply Direct Link To This Post Posted: 09 Dec 2010 at 12:10pm
Joe
Thanks Joe..
After this is resolved going to have to send one to a gear distributor and find a replacement version for the future...
Bob D. (La) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bob D. (La) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Dec 2010 at 12:23pm
Tom, Don't know if it will help. I had a WD45 Hi Crop I needed to get a tie rod end loose. Tried everything else, then got out the fire wrench. Did not work either. Tried a couple more ideas but all for nothing. Ran out of day and quit. The next day went out expecting to have to cut it off and it was loose. Came right off. Don't know why, but it made my day the next day anyway.
Italy Hill Produce View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Italy Hill Produce Quote  Post ReplyReply Direct Link To This Post Posted: 09 Dec 2010 at 12:27pm
I have two parts AC 60's in upstate NY if you send me a pic I can see if I have what you need (not that I'll have much luck getting one off either)
Jonathan
G tractor and an All Crop 66
Also Kubota MX5100F and M9540HD12
ALinIL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ALinIL Quote  Post ReplyReply Direct Link To This Post Posted: 09 Dec 2010 at 12:27pm
Tom
 You might try cutting off the stub shaft on the auger  so that you can get the gear and shaft in a press.  Just a thought. - AL
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomYaz Quote  Post ReplyReply Direct Link To This Post Posted: 09 Dec 2010 at 12:43pm
You should have played the lottery that day.  We did give it two seperate attempts.  My fab man tried one day, then I tried it with him another day...
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomYaz Quote  Post ReplyReply Direct Link To This Post Posted: 09 Dec 2010 at 12:45pm
Originally posted by ALinIL ALinIL wrote:
Tom
Dont want to cut the auger..
Edited by TomYaz - 09 Dec 2010 at 12:48pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomYaz Quote  Post ReplyReply Direct Link To This Post Posted: 09 Dec 2010 at 12:47pm
Jonathan
thanks for the offer Jonathan.   I got someone looking for one thats already off.  Lets see if that pans out.  Would hate to put you thru it! ... This gear has a beveled backside and the puller claws just slide off that backside when you get enough tension applied.
Frustratin!
Rawleigh View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rawleigh Quote  Post ReplyReply Direct Link To This Post Posted: 09 Dec 2010 at 1:05pm
Tom:  Use a bearing separator to get a purchase on the shank of the gear, then use the gear puller on that.  Heat it up red hot and then quench it in a bucket of water.  Put on the separator and pull the separator with the puller to get it off.   Two pieces of scrap steel of sufficient strength with allthread through them will work as a substitute.  You can also use wax from a toilet bowl ring to melt around the shaft.  Keep the heat at the opposite side of the gear from the wax and it will wick it into the crack.
http://www.harborfreight.com/large-bearing-separator-3979.html
Edited by Rawleigh - 09 Dec 2010 at 1:08pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Skyhighballoon(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Dec 2010 at 1:13pm
Tom - I used this HF bearing puller kit for the 1st time last weekend to pull a stuck generator pulley and it worked GREAT.  It's a full kit version of the item Rawleigh just listed.  Mike
http://www.harborfreight.com/bearing-separator-and-puller-set-93980.html
1968 Gleaner EIII w 10' & 330
1969 180 gas
1965 D17 S-IV gas
1963 D17 S-III gas
1956 WD45 gas NF PS
1956 All-Crop 66 Big Bin
R Aiken View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote R Aiken Quote  Post ReplyReply Direct Link To This Post Posted: 09 Dec 2010 at 1:22pm
Originally posted by TomYaz TomYaz wrote:
Folks,
if you would come get those parts machines , you would have the parts you need.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomYaz Quote  Post ReplyReply Direct Link To This Post Posted: 09 Dec 2010 at 2:21pm
Folks,
Yah, and the gears would just as stuck!
When the weather is nice again Rich....
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomYaz Quote  Post ReplyReply Direct Link To This Post Posted: 09 Dec 2010 at 2:24pm
Yep sounds like that would do the job...
John WV View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote John WV Quote  Post ReplyReply Direct Link To This Post Posted: 09 Dec 2010 at 2:27pm
Tom I have heat parts red hot and then pour ice water on it  and put the puller on it and will come I think the soulden change in the temp. breaks up the rust.  John
den/southern illinoi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote den/southern illinoi Quote  Post ReplyReply Direct Link To This Post Posted: 09 Dec 2010 at 5:06pm
Tom,
I sent you a PM.
Den
Own 4 wheel 20, 2-5015, 5020 and associated equipment and 2 electric forklifts.
KevinON View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KevinON Quote  Post ReplyReply Direct Link To This Post Posted: 09 Dec 2010 at 5:19pm
Tom, I have a parts 60 as well if you are stuck.  Let me know.  Take care.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomYaz Quote  Post ReplyReply Direct Link To This Post Posted: 12 Dec 2010 at 4:21pm
Well guess what?
Went back to the offending bearing and got it off.  I noticed the opposite side of the gear puller claw arms had a different stlye "tooth" on the end. Figured I would try it. Voila, it was able to hold on to the gear. But that gear was a sumb*tch to get off; it was stuck on there good!
