Ok y'all here is that D 14
captaindana View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote captaindana Quote  Post ReplyReply Direct Link To This Post Topic: Ok y'all here is that D 14
    Posted: 08 Dec 2010 at 5:22pm
that I found yesterday...if can post a pic that is. Original, no rust, ps, but original skins, she's a 57. What should I offer? If you knew me you'd know she will get new skins, paint, brakes, clutch, etc...let me know what to offer. Thanks!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote captaindana Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2010 at 5:24pm
Well original rear skins that is...guy sprayed with it and wanted the smooth wide fronts...
BennyLumpkin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BennyLumpkin Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2010 at 5:54pm
Id take it!
Central PA Allis Express
1934 WC254
1945 WF
1945 WC135755
1951 WD68085
1953 WD45-150217
1957 WD45D-230744D
B110
Matt MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt MN Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2010 at 5:54pm
Hey Captain, wasn't it you that was restoring the D15 that you called (diamond)?
How did that turn out?
Matt
David Gibson (OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote David Gibson (OH) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2010 at 6:06pm
Looks to be good and straight.
David Gibson
http://www.darkecountysteam.com
1956 WD45
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2010 at 6:23pm
Well Captain, I know of one that hasn't ran in about 5 years,has sat outside all that time, has a tree laying across it, a trip loader and no drawbar with a blade welded up and mounted directly on the lift arms, and they guy wants $2000 for it. Oh I forgot it looks like about 1/4 as nice as that one and it needs new rear rims and tires all around.  Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2010 at 6:25pm
I also know of a dropped FFA project that has good rims and is laying on 3 pallets in a machine shed. I can't get the guy to give me a price. I know he gave like $200 for it and hauled it up here from Texas to find out his brother doesn't want to fix it for him.
Chuck(ONT) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chuck(ONT) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2010 at 7:07pm
Does it jump out of any gear? Could be an expensive repair. Also the 26" rears are way up in price, but you could put 28's on it.
Never take life too seriously.
Nobody gets out alive anyway!
1C 1 WD45 1 AC180
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2010 at 7:58pm
Original?? 1957's had the grille screen painted orange and silver/grey decals on the hood instead of rivet-on emblems...also air cleaner hose should be molded, not a radiator hose with wire inside of it.
Jordan(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jordan(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2010 at 8:29pm
Looks like it either has a gas leak or the front and rear half were different tractors at one time.
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2010 at 8:31pm
I have to agree with Dr. Allis.  Air breather should be taller and the front rims look wider than stock as well.  Overall, it looks decent and would be worth it if the price is right.
Rogers View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rogers Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2010 at 8:34pm
It is a nice looking tractor. If it runs and doesn't jump out of gear then it is worth several thousand dollars. If it needs engine repair and transmission work then I wouldn't give that much.
You asked for a off the cuff price. I would offer 1,500 to start if it doesn't need engine and transmission work. If they don't take it, you can always go up, but you can't come down. My upper price would be 2,500, but it would have to be in good shape for that. Tires and paint will be expensive. If it needs work I would probably offer 1,000 with an upper range of 1,500 dollars.
That is just me though. It really depends on how bad you want it. How much you give is really a comfort thing. I have given more than I really believed something was worth just because I wanted it. Good luck, it is a nice looking tractor.
Think for yourself and be your own expert. Be willing to change your mind; however, willingness to change your mind doesn’t mean that you will. Blindly following any path is the pinnacle of insanity.
JohnCO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnCO Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2010 at 10:33pm
Long time no hear, Capt.  Looks like a nice one.  I'd give $2,000 if it were near by and everything worked as it should.
Allis Express participant
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2010 at 10:46pm
If engine sounds OK ( no knocks ) decent oil pressure ( RMA area ) and doesn't jump out of any gear, I'd say 1200 to 1400.
Look like D-15  hoods !
Gary
Eldon (WA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2010 at 11:40pm
I gave $3250 for this one at auction a couple of years ago. The rear tires are worn, and the pd pops out of the high side, but the tranny is good, has ps and came with #7 sickle mower, 52 sc plow, loader, sc field cultivator, and 9' sc blade. I think that puts the tractor around $2000.
Edited by Eldon (WA) - 08 Dec 2010 at 11:43pm
ALLIS EXPRESS!
This year:
SHAMELESS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Posted: 09 Dec 2010 at 2:33am
welcome back capt!!
B26240 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote B26240 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Dec 2010 at 7:29am
Capt I would offer $1000 . There are still plenty of D14' out there.
Jim Lindemood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim Lindemood Quote  Post ReplyReply Direct Link To This Post Posted: 09 Dec 2010 at 8:14am
Good to see a post from you.  Well, there you have it -- value of many amounts. Still comes down to condition of tractor, location of tractor, and how bad ya want the tractor. I have probably paid more for things that ran good, close to home, and something I thought I really had to have  - LOL.  Also consider, do you want to restore to use in field (best kind) or restore to be absolutely correct for collection? Fair value? - follow your heart and be happy with the results.
Charlie175 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Dec 2010 at 9:04am
$1500.
I do see them advertised for $2000 to $4000 around here.
Charlie
Bob D. (La) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bob D. (La) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Dec 2010 at 11:59am
Is it home yet Cap'n. Sure hope you can work out a favorable deal on it. God Bless.
1946WP View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1946WP Quote  Post ReplyReply Direct Link To This Post Posted: 09 Dec 2010 at 5:48pm
I gave $1200 for this one. engine needed alot of work. but trans works fine. sold the back blade that came with it for $150. Before & after pics.
This page was generated in 0.165 seconds.
