Gleaner E motor info needed.
Pa.Pete View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pa.Pete Quote  Post ReplyReply Direct Link To This Post Topic: Gleaner E motor info needed.
    Posted: 08 Dec 2010 at 5:02pm
Can anybody tell me what the line coming from the bottom of the oil pan is for and can you eliminate it when putting this motor into a WD? I did a seach and can't seem to find anything. My Father inlaw is thinking of doing this swap but he want's to know what that line is for. I'm sure someone on here knows, you guys know just about everything.
Thanks,
Pete
wi50 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wi50 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2010 at 5:07pm
engine oil drain line on the combine as the engine sits low.  Just replace it with a drain plug.  I've seen new plugs listed from some of the aftermarket suppliers
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pa.Pete Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2010 at 5:09pm
That's easy. I thought it might be something important.
Thanks
This page was generated in 0.042 seconds.
