aftermarket 3 point question
tnac View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tnac Quote  Post ReplyReply Direct Link To This Post Topic: aftermarket 3 point question
    Posted: 07 Dec 2010 at 7:35am
What is the best brand of aftermarket 3 point for a D-17? Any opinions? Thanks
Chris/CT View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris/CT Quote  Post ReplyReply Direct Link To This Post Posted: 07 Dec 2010 at 8:24am
I have a AC SC to 3pt adapter that has alway's worked well, I do not need it. Missing stabilizer, otherwise straight and nice condition if u decide to go that route.
GregLawlerMinn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GregLawlerMinn Quote  Post ReplyReply Direct Link To This Post Posted: 07 Dec 2010 at 8:26am
Talk to Tony D (OK Tractor) and/or Tony C (Tonys Tractors). They both supply high quality hitches and are very helpful in assissting you to select one for your needs. Both advertise in the "Parts, etc" page of the forum
JimD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JimD Quote  Post ReplyReply Direct Link To This Post Posted: 07 Dec 2010 at 8:54am
Give me a call or shop around my website.  We carry the Cross brand, and the worksavers.  Worksavers are way overpriced, but some folks really want them.  I prefer the Cross and it's what I have used on my Wd, WD4, B, D14, D15 series II, and D17. They are made in Missouri, and very well built.
Cross makes 2 that wll fit your D17.  I would be happy to explain the differences. Just give me a call toll-free.
JImD
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pat the Plumber CIL Quote  Post ReplyReply Direct Link To This Post Posted: 07 Dec 2010 at 10:28pm
Depends on what you plan on using it for.If you have both 3pt and snap coupler equiptment you want something that can come on and off easy.If you only have 3pt. equiptment and plan on heavy use,get the higher priced bolted on version that cannot easily be taken on and off.I have seen several versions through several vendors.Jim D., Tony C.,Saginaw Hitches.Call around and these guys will answer all your questions.
Harvey/pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Harvey/pa Quote  Post ReplyReply Direct Link To This Post Posted: 07 Dec 2010 at 10:59pm
 I had a Worksaver on my D17, nice heavy unit but had to remove the drawbar. I sold both at a consignment sale & they were separated. Son-in-law bought the D17 back 18 months later with a different 3pt (homemade I'm sure) but alot more functional as the drawbar could be used without removing the 3 pt. We wouldn't have it any other way now HTH...Harvey
Burgie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Burgie Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2010 at 5:14am
I like the Cross because you still have the factory drawbar. Your traction booster will work with the Cross.
"Burgie"
Jim-Ohio View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim-Ohio Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2010 at 5:48am
We've had a Saginaw on ours for 5 years now. Works great. Still uses snap-coupler draw bar.
Jim Lindemood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim Lindemood Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2010 at 7:58am
I have a Cross from Jim D. -- I have a mix of SC and 3pt equipment -- have foud this hitch works fine for me -- still uses factory drawbar. Have not experienced any problems.
Kip[NY] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kip[NY] Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2010 at 9:37am
We have a Cross from Tony Carbaugh on our D-14, which as others have said, means we still have the drawbar available - and we use both so it's a nice set-up.
1959 D-14 SN/21089 "Martha"
Bob-Maine View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bob-Maine Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2010 at 4:12pm
I put a Saginaw on my D-14 several years ago. It is a rugged unit. I was moving 1000# units of firewood with a 3 pt. fork attachment today. Don't have power steering so this operation takes the place of it. Sometimes need to brakes to steer. Bob@allisdowneast
This page was generated in 0.104 seconds.
