What is your main tractor?
AndrewGubbels View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AndrewGubbels Quote  Post ReplyReply Direct Link To This Post Topic: What is your main tractor?
    Posted: 06 Dec 2010 at 10:13pm
Hey guys just checking to see what your main farm tractors are?  We have alot of 7000 and 8000 series tractors.  Along with some CASE tractors.  We use the 190xts and 200's for alot of handywork also.
ANdrew
Andrew Gubbels
Gubbels Restoration
ScottinSWIL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ScottinSWIL Quote  Post ReplyReply Direct Link To This Post Posted: 06 Dec 2010 at 10:25pm
 As far as the main fieldwork tractors would be the Agco's- 205b and DT200, AC 8070, JD 4450.  The tractor that has the most hours put on every year is the NH TL100 FWA with a loader for all around jobs such as hay and daily chores with the livestock.  Also have an AC 180 that gets light duty jobs.
Craig/insoh View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Craig/insoh Quote  Post ReplyReply Direct Link To This Post Posted: 06 Dec 2010 at 10:30pm
We use 175 with 500 loader, 6080 MFD with Dual 205 loader, 7060PS with 470 loader, and Versatile 276 with loader! We use all for feeding in winter, and grinding feed! All used for haymaking also! 7000 series for field work! Also have 185, 190XT, 190XT series3, 6080 2wd, 3 7030's, 7050, and 7080!
Claus View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Claus Quote  Post ReplyReply Direct Link To This Post Posted: 06 Dec 2010 at 10:37pm
I have big tractor envy but don't have the shed space for one nor can I  justify anything larger so this is it for now.
Edited by Claus - 06 Dec 2010 at 10:38pm
JimIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JimIA Quote  Post ReplyReply Direct Link To This Post Posted: 06 Dec 2010 at 10:54pm
In all honesty for the size of equipment we have on our small old fashioned operation I use my D15 for more things than anything.  It is just the handiest little rig, now we put an A-C two way hydraulic valve on it so it will probably get used more!  Of course all of the others find their place and we would be lost without the 170 and loader, the 185 is a very handy tractor as well.
Steve M C/IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve M C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 07 Dec 2010 at 12:04am
8070 with heat and AC.220 for fun in the sun and the WD45 does the planting and bushoggin.WD has the scoop....very handy.
Nathan (SD) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nathan (SD) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Dec 2010 at 12:12am
We got a 1715 Ford that kind of took over the D17 work.
Hard to believe the nuts that little tractor got.
JohnCO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnCO Quote  Post ReplyReply Direct Link To This Post Posted: 07 Dec 2010 at 12:19am
For heavy field work, the 7580 is my choice.  For cutting and baling hay I like the Kubota M110.  For odds and ends a Ferguson 40 (not MF) and once I get 3d gear fixed a D14.  For cultivating a G.  For digging and loading, a Ford 555 B tlb and a JCB 185 robot skid steer
Allis Express participant
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 07 Dec 2010 at 5:50am
190XT is what I use most. Nimble, powerful, comfortable, super easy on fuel and super easy to drive. It's the only tractor my wife is willing to drive.
Edited by Lonn - 07 Dec 2010 at 5:51am
Wink
I am a Russian Bot
RSallis-pullinMD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RSallis-pullinMD Quote  Post ReplyReply Direct Link To This Post Posted: 07 Dec 2010 at 6:16am
I have a JD 7410 Cab FWD and 741 loader use it on farm and in my excavation business,most handy tractors are our 2 4710's with loaders,also have 4720 with cab ond loader,AC's D19diesel,19gas with 500 loader,WD,WC,CA and many AC engines and parts and M2 caombine
Good View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Good Quote  Post ReplyReply Direct Link To This Post Posted: 07 Dec 2010 at 6:23am
Our 45 with a kelly loader gets used way more than anything but for the hay operation it was the 45 with 262 gas motor. This year we borrowed my uncles 175 wich was much better and when I get the XT ready it will be the main field tractor. Like Lonn said real comfotable. Iam a little worried about the handclutch being jerky an knocking everybody down on the wagon though.
B212,716,two 314H's,WC,WD,D19,190XT
TEDMI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TEDMI Quote  Post ReplyReply Direct Link To This Post Posted: 07 Dec 2010 at 6:25am
I don't really farm but do have 2 I use the most, it would be a WD , for plowing snow , CA  hauling wood.
    TEDMI.
Edited by TEDMI - 07 Dec 2010 at 6:42am
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 07 Dec 2010 at 6:44am
You get good at feathering it. I did, my wife did and you will too. Although my Dad seems to about throw me off the wagon from time to time. I think the gate type like the 200 has might work even better as it can be hard to push the lever down on the XT. I always was going to try to modify the XT at some point to make it easier to push the lever down. Maybe a lighter spring? Never had one apart in that area.
Wink
I am a Russian Bot
allisorange View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allisorange Quote  Post ReplyReply Direct Link To This Post Posted: 07 Dec 2010 at 7:13am
       A 7000 and a 190XT do the heavy work here. AD17 with a New Idea loader gets a lot of use in the summer and winter.
                                     John Carlson
Ben (MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ben (MI) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Dec 2010 at 7:24am
Andrew-sounds like you have a great lineup. I farm 100 acres corn/soybeans with a late model 7000.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ben (MI) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Dec 2010 at 7:26am
JimIA-I LOVE the pic of the ear corn unloading.
Stan IL&TN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan IL&TN Quote  Post ReplyReply Direct Link To This Post Posted: 07 Dec 2010 at 7:39am
Well the 170 for mowing 7-8 acres.  The F40, not sure yet.  Maybe keep the blade on it.
1957 WD45 dad's first AC
1968 one-seventy
1956 F40 Ferguson
tnac View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tnac Quote  Post ReplyReply Direct Link To This Post Posted: 07 Dec 2010 at 7:41am
used to be faithful to agco but.............................
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 07 Dec 2010 at 7:50am
Since my farming has been downsized to hobby status with 250 acres of crop, the JD 4250 (cab and heat) is the plowing and snowblowing tractor, D-21 II with duals does 400 ac of cultivating each year pulling an A-C 1300 24.5'. A 220 is getting ready to pull the fall deep tillage tool. D-15 II brush cutting, D-12 III finishing mower, WD-45 80R all to keep up road ditches, D-17d IV wood splitter/ 30' roller. A-C 715B TLB stone picking etc. H-3 blade misc jobs. Too many A-C's and not enough jobs.
ACFarmer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACFarmer Quote  Post ReplyReply Direct Link To This Post Posted: 07 Dec 2010 at 8:00am
Just getting my farming operation started but I have a 7080 for my heavy work when I get it done and a 210 for planting and lighter type work. I have a 1550 Oliver for odd jobs also.
Making a living farming with and working on Allis Equipment
JC-WI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 07 Dec 2010 at 8:25am
what is the main trtactor? depends on the time of year. Spring time plowing, discing and cultivating the 4520, 190XT on the planter. summer 190XT Diesel, 190 gas, 200 and D17 for haying. Fall harvest WD on LPgas with mounted 33 picker for ear corn and K combine for grain. Winter 170 with loader for feeding round bales and getting wood out of the woods to burn and the WD45 for pushing snow.
Ken in Texas View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ken in Texas Quote  Post ReplyReply Direct Link To This Post Posted: 07 Dec 2010 at 8:31am
MF 1260.  I borrow the 1260 rear rims and water filled tires for my CA when I go pulling.
Poor folks have poor ways. We are so poor the poor folks talk about us.
JimD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JimD Quote  Post ReplyReply Direct Link To This Post Posted: 07 Dec 2010 at 10:04am
D15 Series II for dragging stuff around and brush-hogging.  B (my son's) runs a finish mower and mows between 7-15 acres.  But hoestly its my Borg-warner rough-terrain forklift that get's used the most, and it's in the worst shape.
JImD
farmboycitygirl View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote farmboycitygirl Quote  Post ReplyReply Direct Link To This Post Posted: 07 Dec 2010 at 10:15am
Use a 7020 for field work, discing, plowing, etc. baling hay.
190 XT III to mow hay, grind feed, feed the cows.
180 to rake hay using a vermeer twin rake, drill post holes, all around stuff.
CA mows the lawn
Farmall f20 to have fun with
Blake_AllisMan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Blake_AllisMan Quote  Post ReplyReply Direct Link To This Post Posted: 07 Dec 2010 at 12:55pm
On our farm we use a 185 to plant the crop with.
The 200 and 7045 to pull the wagons into town with.
The C to move wagons around and sometimes for some fun pull loads into town with.
1941 C
1952 IB
1947 C
1955 WD45 SFW
1956 WD45 Diesel
1977 5020 4WD Serial Number 1
Brian F(IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian F(IL) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Dec 2010 at 1:58pm
My main tractor is my '52 CA.  But my farmin' buddy's big outfit is a JD 8430.  Both are fun to operate.
John In. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote John In. Quote  Post ReplyReply Direct Link To This Post Posted: 07 Dec 2010 at 2:44pm
I only have one a 54 WD45. In the winter I use it to plow snow. In July I use it for baling straw with a 302 baler and cutting down the weeds later with an 80R mower on my son-in-laws land and his buddies land. Does a quick job disking the small garden too, 2 passes and done, lol.  John
RSponenberg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RSponenberg Quote  Post ReplyReply Direct Link To This Post Posted: 07 Dec 2010 at 3:22pm
I farm 108 acers with a CA and 2-WD45s with the CA getting the most use,mainly because its the cheapest to run!!!
Daehler View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Daehler Quote  Post ReplyReply Direct Link To This Post Posted: 07 Dec 2010 at 3:26pm
One of my main tractors is a 80' 7080 for tillage and a 74' 200 for bailing and brush mowing. Plus 10 other AC's for small jobs.
Joe(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Dec 2010 at 4:21pm
My main tillage tractor is a 7020 and my main planting tractor is a 190XT.  But I dont know where I would be with out a D-17.  Im also found of the CA and the......
Life is simpler when you plow around the stump.
This page was generated in 0.283 seconds.
