Allis Chalmer D14 Dipsticks
papastanh View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote papastanh Quote  Post ReplyReply Direct Link To This Post Topic: Allis Chalmer D14 Dipsticks
    Posted: 06 Dec 2010 at 7:12pm
First I am getting a service manual for Christmas. But until then I have a couple of questions. Right behind the oil filter towards the back of the tractor there is a dipstick, what is it for, what kind of oil.   Then on the other side of the tractor right behind the instrument pannel on the top is a bolt/dipstick, what is it for and what kind of oil. I understand they may be either hydraulic or gear boxes. Thanks in advance for any advise.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 06 Dec 2010 at 7:37pm
From front to back..
right side,behind oil filter is the Hydraulic pump and belt pulley oil filler
Left side,under steering column is the Power Director clutch filler
Left side,across from shifter is the Transmission filler
If you drain all the fluids( I use a 5 gallon bucket), you can then refill them all with a 'Universal Tractor Hydraulic Oil'. Sure makes it easy ! Engine oil for the engine...though !
hth
Post Options Post Options   Thanks (0) Thanks(0)   Quote papastanh Quote  Post ReplyReply Direct Link To This Post Posted: 06 Dec 2010 at 7:42pm
Big Thanks there jaybmiller! New to this tractor game but sure have fun learning. Your advise will be helpful! Thanks again
This page was generated in 0.043 seconds.
