I'm pretty sure my WD45 is a divining rod for.....
Roddo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Roddo Quote  Post ReplyReply Direct Link To This Post Topic: I'm pretty sure my WD45 is a divining rod for.....
    Posted: 05 Dec 2010 at 12:03am
Rocks.
Big ones.
A year or so back I was using the SC subsoiler and the tractor bogged a bit then lurched forward sharply.  I looked back and the blade and a chunk of the pull frame of my subsoiler were a lot farther behind me than the rest of it.  It broke in half!
Today I was plowing with my 3-14 semi in a section of field that my dad has worked for 25 years.  Its purring along in 3rd gear without a care in the world, then BANG!
I nearly lose half my teeth on the steering wheel and the plow is standing up with the tail wheel in the air.  The first bottom found a damn rock that had to be 3ft by 3ft.
Should I just park this thing before destroy it?
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 05 Dec 2010 at 7:36am
You need the hand clutch kick out linkage.
Wink
I am a Russian Bot
Brian G. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 05 Dec 2010 at 8:34am
Nearly all of the WDs and WD-45s in my part of NY state (ROCKY) have the hand clutch "kick-out" linkage. I have had no luck finding a description or drawing in my WD-45 operator's or parts manuals. Neither coluld I find it shown in my WD-52/WD-53 plow manual. I may have to go out and take a picture of it on my WD or WD-45!
jiminnd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jiminnd Quote  Post ReplyReply Direct Link To This Post Posted: 05 Dec 2010 at 9:15am
Absolutly get the clutch release, have plowed with one for 50 years and no breakage of plow or teeth, for 15 years plowed hundreds of acres a year, now just a few hours a year.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 05 Dec 2010 at 3:22pm
Here are a coupla pics of the "kickout" on my WD. I don't remember it being welded; my Dad must have done it years ago; he bought it in '58.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Roddo Quote  Post ReplyReply Direct Link To This Post Posted: 05 Dec 2010 at 5:03pm
I think any way you slice it that would be a good idea, but I just seem to be able to find the only rock in a non rocky field.  Just bad luck I guess.
Bull View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bull Quote  Post ReplyReply Direct Link To This Post Posted: 05 Dec 2010 at 5:10pm
Yeah, that clutch release works good. When I was a little tyke 50 years ago I sat in my dad's lap while he plowed with his 45 Diesel. I had a face to face encounter with the steering wheel a time or two when the clutch tripped. Thosw were good times though.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 05 Dec 2010 at 5:12pm
Maybe you found the last 2 rocks and it won't happen again in your lifetime.
JohnCinMd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnCinMd Quote  Post ReplyReply Direct Link To This Post Posted: 05 Dec 2010 at 5:51pm
What's the purpose of the wing-nutted guide? Is it to adjust the handclutch position so it'll kick out easy?
Osage_Orange View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Osage_Orange Quote  Post ReplyReply Direct Link To This Post Posted: 06 Dec 2010 at 8:57am
I'm going to try to make one.  Looks like 5/16 or 3/8 steel.  Am I close?
Edited by Osage_Orange - 06 Dec 2010 at 8:58am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 06 Dec 2010 at 9:03am
John,  it is obvious that the arm is adjustable. I have never touched the adjustment. I have not been able to find a  manual that describes its operation but I'm assuming that it might be to compensate for clutch wear and/or allow some discretion as to how much of a "jolt" you want to subject your equipment to.
I have never plowed much with the WD but I have "snapped" the clutch a few times when "ditching" with the back blade. I have also "snapped" the clutch several times when pulling stumps.
John In. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote John In. Quote  Post ReplyReply Direct Link To This Post Posted: 06 Dec 2010 at 1:46pm
 John & Brian, If you look at the first pic you can see the stapcoupler pin, when plowing , and you hit a ROCK  the plow stops but the tractor keeps going, the big spring contracts and the pin hits the tab (that piece of metal to the left of the pin ) which knocks the hand clutch out and stops forward movement of the tractor. You can adjust  it with the thumbscrew by loosening it and turning the guide.  HTH  .John
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 06 Dec 2010 at 3:07pm
BTW, this tractor origiunally had the pin-hitch with the clutch "kickout". Only after I got the snapcoupler back blade, did I replace the pin-hitch with the snap coupler bell.
