HD5 dozer
BiG210 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BiG210 Quote  Post ReplyReply Direct Link To This Post Topic: HD5 dozer
    Posted: 04 Dec 2010 at 6:40pm
I'am looking for a blade to fit a 1953 model hd5 thank you
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 04 Dec 2010 at 6:58pm
Just blade or full dozer set up , several mfg made the units , Most used a system to run arms to the rear Axel outboard bearing flange to use as the push base.
  Lift systems varied in where they had bearing point on the truck frame  as the truck oscillate unlike the 5G which had a solid truck frame cross-member.
here is one I had not seen before in type of lift as it uses tractor mainframe as part of lift hardware.
Edited by Coke-in-MN - 04 Dec 2010 at 7:01pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote BiG210 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Dec 2010 at 7:04pm
Just the blade is what i need it has a hyd fram that goes from the rear around the front to single pin hole in the front i think maybe garwood or backer but don't know thanks
dadsdozerhd5b View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dadsdozerhd5b Quote  Post ReplyReply Direct Link To This Post Posted: 05 Dec 2010 at 4:27pm
i have a baker blade setup i was just thinking of scrapping. i will send you a pm with pics.
