AC Garage Art
Jeff(WD45-SATX-TN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff(WD45-SATX-TN) Quote  Post ReplyReply Direct Link To This Post Topic: AC Garage Art
    Posted: 03 Dec 2010 at 3:46pm
Need to get my stencil adjusted a bit for the lettering. Also outilne the letters with a contrast color. I am working on some silk screens for tee shirts. We'll see how this goes....
Started as this:
Shaded and stenciled as this:
Edited by Jeff(WD45-SATX-TN) - 03 Dec 2010 at 3:59pm
1954 WD45 NF "Iron Tater"
omahagreg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote omahagreg Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2010 at 9:33pm
COOL!
Greg Kroeker
Orangeknight View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orangeknight Quote  Post ReplyReply Direct Link To This Post Posted: 06 Dec 2010 at 5:06pm
Neat! How long did it take you and how big is it?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff(WD45-SATX-TN) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Dec 2010 at 6:27pm
Orangeknight
That is a panel inset on my metal garage door. Picture itself is little bigger than 8X10. I worked that drawing up in about an hour. Then shading for the stencil took a couple hours of trial and error to get it right in order to cut the dark sections out and keep the area continuous. Made a thick paper stencil out of it. All the shaded areas were cut out with an Exacto knife. That took several hours easy. Same with the lettering. Drew those up in Auto CAD and then printed and cut. Laid down the black first, over the orange, then the white letters. I have revised this with a two tone stencil set to give better definition. Also using a thicker plastic stencil material. Will post the revised version when I get it done.
Thanks
papastanh View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote papastanh Quote  Post ReplyReply Direct Link To This Post Posted: 06 Dec 2010 at 7:19pm
Now that is way COOL. Nice drawing!
darrel in ND View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 06 Dec 2010 at 9:30pm
I agree, cool!!!   Darrel
