D14 won't start
Gary (sw Wis.) View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary (sw Wis.) Quote  Post ReplyReply Direct Link To This Post Topic: D14 won't start
    Posted: 03 Dec 2010 at 12:17pm
My D14 that I use at least weekly won't start. It was not running as well the last few weeks. Started hard, had to feather the choke way more than normal, lacked power, had to baby the clutch and just didn't sound like her old self. Gas flow from tank is good and I replaced the points and condenser and now it fires some but still won't start. Any sugestion on where I should start would be great thank.
190XT - D17 - D14 - WD45 w/loader - WD - (2)B110 - 616H - 610 - B-208 - WD with 190 Mounted Corn Picker - All Crop 60
john(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote john(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2010 at 12:26pm
Did you take out the plugs and dry them?  When it gets cold, gas doesn't vapoize, and will wet the plugs causing that problem.  I used to use a cigarette lighter, but quit smoking, so now I just use stick matches.
Goose View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Goose Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2010 at 1:01pm
Could be your ignition coil went bad.
Stan IL&TN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan IL&TN Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2010 at 2:03pm
Battery good?  Need a good battery for ignition to function properly.  If plugs are wet then it's flooded or ignition is not working.  If you have good spark at the plugs and the plugs come out dry then it may be fuel issue.  Give it a shot of starting fluid and if it wants to run on that then you need to look at the carb.
1957 WD45 dad's first AC
1968 one-seventy
1956 F40 Ferguson
FredW View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FredW Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2010 at 2:10pm
Sounds to me just clean the carb. everything else was mentioned. Had one do that was dirt in the gismo, wouldnt let enuf gas thru. Fred
Burgie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Burgie Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2010 at 2:15pm
And Fred knows gismo`s!!!!
"Burgie"
Post Options Post Options   Thanks (0) Thanks(0)   Quote FredW Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2010 at 3:57pm
I will take that as a compliment. Fred
Blake_AllisMan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Blake_AllisMan Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2010 at 4:29pm
I would say it sounds like a carb. issue. Maybe clean inside the carb and put a new carb kit in it.
1941 C
1952 IB
1947 C
1955 WD45 SFW
1956 WD45 Diesel
1977 5020 4WD Serial Number 1
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2010 at 5:06pm
Before you go tearing into the carb, check your ignition system first. Replace those used up points and condenser and then see how she runs...
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary (sw Wis.) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Dec 2010 at 5:40pm
Thanks guys. I have good spark so I guess now I have to take the carb to some one for a good cleaning and kit.
norm[ind] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm[ind] Quote  Post ReplyReply Direct Link To This Post Posted: 04 Dec 2010 at 7:44pm
  CHAMPION PLUGS HELP THE ISSUE TO NOT STARTING ALSO
