wiring question for WD 12 volt
Don(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MI) Quote  Post ReplyReply Direct Link To This Post Topic: wiring question for WD 12 volt
    Posted: 03 Dec 2010 at 11:56am
Just a quick dumb question. I will be wiring the WD tonight, this tractor was set up with a 12 V alternator previously, I changed that to a 12V generator.
When wiring the amp, should the lead come off one terminal of the battery, and the other lead to the other terminal?
Might sound dumb, but this really is my first wiring job!
Also, has anyone documented a wiring diagram for a 12V with generator?
thanks, Don
Roddo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Roddo Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2010 at 12:07pm
You mean the ammeter?  Pick up power from the lug at the starter, run it to the ammeter, then take any other power wire  to the other side of it, such as lights, ignition coil, etc for it to read properly.  Are you going to a 12v neg ground as well?
This site is ripe with info for many wiring related stuff for out old orange tractors.
Edited by Roddo - 03 Dec 2010 at 12:09pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2010 at 4:34pm
Yep, the ammeter. And yes it is a negative ground. Thanks!
Edited by Don(MI) - 03 Dec 2010 at 4:35pm
