I-60 vs. I-600 ID
Post Options Post Options   Thanks (0) Thanks(0)   Quote TimNearFortWorth Quote  Post ReplyReply Direct Link To This Post Topic: I-60 vs. I-600 ID
    Posted: 03 Dec 2010 at 5:24am
Did all I-60 units come equipped with the 160 motor?
I am helping a friend ID a unit and am not familier with where the s/n is located on these forklifts; no numbers appear to be stamped on the torque tube flange where found on any of my D Series ag units. Unit has the somewhat rounded grillwork, vs. the more square sheet metal of the later (I-600?) units. Friend is looking to convert this unit to LP and the "throat" of the manifold looks to be very small, when compared to my D15II tractors.
What engine numbers stamped on the block would determine if 149 or 160?
Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote TimNearFortWorth Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2010 at 7:38am
Also, unit does have oval cut-out for muffler.
This fella is looking for a good source for complete (new) LP carb set-up; he will source tank and mounting seperately.
Thanks
skipwelte View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote skipwelte Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2010 at 10:33am
An I60 is a constructionized version of a D15 II.  It does have the 160 engine, oval muffler, lites on the fenders.   The only difference between the I60 and I600 that I have found is the badge on the front grille is different between the two.  The hard nose and grille should be the same between the two.  Your friends may have some owner mods over the years too.   HTH
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 04 Dec 2010 at 8:12am
Skip is right. I had an I-60 backhoe. The difference between the I-60 and I-600 was the backhoe not the tractor. The same most likely applies to the forklift part if there are any differences at all.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TimNearFortWorth Quote  Post ReplyReply Direct Link To This Post Posted: 05 Dec 2010 at 9:01am
Hmmm; been thinking about what he will potentially do if converts it to LPG.
Different compression as I recall, vs. the gas motors .......
Any thoughts on potential burning of pistons?
His reasoning for the conversion is he wants a more finite control on his throttle when his workers use this unit for his pole barn building business.
Any thoughts are welcome as always.
Thanks
