D230 & D262 Head Bolts, What to Do?
Jason(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jason(OH) Quote  Post ReplyReply Direct Link To This Post Topic: D230 & D262 Head Bolts, What to Do?
    Posted: 02 Dec 2010 at 6:34pm
I am rebuilding an engine for a WD45D and need all new head bolts. Went to local AGCO dealer only to be told they are obsolete. So, my question is where can I find new head bolts for a D230 or D262 Allis engines? Would a fastner house have them? I don't really like dealing with Fastenal, but if they have them or can get them, I guess that's what I'll have to do. Thanks, Jason
Gary in da UP View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary in da UP Quote  Post ReplyReply Direct Link To This Post Posted: 02 Dec 2010 at 6:40pm
 If  you have the dimensions contact ARP. My self and others here avoid fastenal. Get the good stuff.
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 02 Dec 2010 at 6:47pm
A friend got ARP head bolts for his D-19 diesel. Took three trys to get the right ones but hopefully that will go a long way to solve the head gasket problems.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TedBuiskerN.IL. Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2010 at 12:50am
ARP has the correct studs on the shelf, but you must be specific as to stud length and thread size and length.  Be sure to get the hardened washers and nuts too.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2010 at 6:28am
I called ARP and they said should be no problem if given the dimensions. They can do either bolts or studs and nuts. At this time, they don't have a package together, but were planning to do one in the future.
Good View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Good Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2010 at 6:35am
I was always told there was a set avaivable that was harder than stock.I wonder were the forktruck guys get there head bolts cause there is a lot of 230's still out there and you can still buy the complete engines from a supplier.
B212,716,two 314H's,WC,WD,D19,190XT
