AC B WHAT IS IT WORTH?
jeff j View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jeff j Quote  Post ReplyReply Direct Link To This Post Topic: AC B WHAT IS IT WORTH?
    Posted: 02 Dec 2010 at 5:24pm
NEW TO COLLECTING AC. SHEET METAL IS GOOD MISSING BELT PULLY MOTOR STUCK REST SEEMS TO BE THERE HAS BEEN STORED INSIDE THANKS FOR ANY HELP
bikley View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bikley Quote  Post ReplyReply Direct Link To This Post Posted: 02 Dec 2010 at 5:27pm
I would go no more than400
split51 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote split51 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Dec 2010 at 5:31pm
 Is it anything special like a low serial number, on steel, arched adjustable front axle,
etc?
Edited by split51 - 02 Dec 2010 at 5:34pm
1929 20-35 sn17662
B1 w/snow blade
B10 w/sickle mower
B110 w/mower deck
B110 w/tiller
B112 w/grader blade
B210 w/plo
Post Options Post Options   Thanks (0) Thanks(0)   Quote jeff j Quote  Post ReplyReply Direct Link To This Post Posted: 02 Dec 2010 at 5:34pm
IT'S NOT ON STEEL DON'T KNOW SER. NUMBER YET THANKS
Blake_AllisMan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Blake_AllisMan Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2010 at 4:24pm
I would say about 400 as well
1941 C
1952 IB
1947 C
1955 WD45 SFW
1956 WD45 Diesel
1977 5020 4WD Serial Number 1
GBACBFan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GBACBFan Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2010 at 4:26pm
If you could post a pic or two folks here could give you a lot better idea.
are genuine." - Mark Twain
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2010 at 4:37pm
Always offer a bit more than current scrap value(so you're not insulting the seller) but remember a nonrunning tractor is very hard to put a price on. A stuck motor could cost $$$$ and you don't know about the clutch,tranny,rearend,etc.Pictures can be priceless ! These guys KNOW their tractors, and you may have a 'diamond in the rough'!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote jeff j Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2010 at 5:04pm
THANKS EVERYBODY WILL TRY TO GET PICS AND SER# THIS WEEKEND
BennyLumpkin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BennyLumpkin Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2010 at 5:05pm
would be worth much more if its and IB
Central PA Allis Express
1934 WC254
1945 WF
1945 WC135755
1951 WD68085
1953 WD45-150217
1957 WD45D-230744D
B110
Post Options Post Options   Thanks (0) Thanks(0)   Quote jeff j Quote  Post ReplyReply Direct Link To This Post Posted: 06 Dec 2010 at 11:52am
ok tractor # b110772 no pics yet thanks for any help
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 06 Dec 2010 at 3:37pm
Sounds like that would be around a 1950. Could be Battery Ignition....
Steve@B&B
morton(pa) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote morton(pa) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Dec 2010 at 3:47pm
1950, Electric start, most likely has hydraulics. No more then 400. Where are you located? Please do not use all caps and turn your caps lock off. Thanks.
B26240 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote B26240 Quote  Post ReplyReply Direct Link To This Post Posted: 06 Dec 2010 at 3:51pm
S/N is found on top of the transmiyion right by the shift lever, also what are the tires like? rubber is expensive.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jeff j Quote  Post ReplyReply Direct Link To This Post Posted: 06 Dec 2010 at 7:19pm
RUBBER IS GOOD. SHEET METAL SRAIGHT. IS ELECTRIC START. LOCATION WINCHESTER VA. MAN IS ASKING $1200. THOUGHT IT WAS A GOOD DEAL BUT I THINK I'LL PASS. THANKS FOR ALL YOUR HELP
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Dec 2010 at 7:31pm
I have paid $6-800 for running tractors.  B is not worth $1200. not running
