opinions on Howard rotavators?
troy(el paso, il) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote troy(el paso, il) Quote  Post ReplyReply Direct Link To This Post Topic: opinions on Howard rotavators?
    Posted: 02 Dec 2010 at 10:11am
Hello All-
Just wanted to know people's opinions of Howard rotavators or comparable 3 pt. tillers.
Thanks......Troy
Eldon (WA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 02 Dec 2010 at 10:37am
The old "Selecta-tilth" models are virtually indestructable....I bought this old guy 9 years ago and have gone thru 2 sets of tines and tons of rocks. This year alone it tilled almost 90 gardens. This 5 footer will make the 175D work at times, and the front end gets a little light when loading it on my trailer.  I have a backup just like it sitting out back...as for the newer models, they just don't look like they are built nearly as heavy.
ALLIS EXPRESS!
This year:
JohnCO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnCO Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2010 at 12:12am
I ditto Eldon.  I heard that they were bought by an Italian company and the quality dropped.  I've got one line Eldons' and other then a pto cross going bad and tines wearing out, it's been a solid machine.
Allis Express participant
Thats "one LIKE Eldons".
Tricky Dickie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tricky Dickie Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2010 at 4:11am
I well remember the old Selectatilth Howards. My father used to grow a large acreage of potatoes and we had a 70" model at home when I was young. It was mounted on a Fordson Super Major and my father used to send the driver off to rotavate potato land with the excess fuel button wired in to give the tractor the extra power it needed to drive the rotavator at full depth. Super Majors had a high geared pto shaft (540 rpm @ 1200 engine rpm) so the tractor needed that bit extra - my father used to take an extra 10 gallons of diesel to the driver at about 2 o'clock each afternoon to keep him going until evening because of the rate the tractor was consuming it!. That roatavator was indestructable and was only replaced when bigger tractors came along and could handle a wider model - again a Howard!
Tricky Dickie
Rayhowling View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rayhowling Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2010 at 6:21am
I  have one like Eldon's, a 5 foot model. I have had it about 10 years and it was 10 years old when I bought it from a friend. I run it with my Allis CA, it makes the CA work but when I brake sod or grass ground I put a bigger tractor on it. They are one tough tiller  and I hang a couple of suitcase weights on the front axle of the CA to keep the front end on the ground. I have a 8 foot model which needs some work done on it. The chain drive is broke and the tines are worn out. Are there any after market companies that make tines for these kind of tillers? I replaced the tines on the 5 foot model a few years after I bought it, but they are pricey.
KenBWisc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KenBWisc Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2010 at 11:03am
They will make a field look like a garden. My father-in-law was a dealer and used one on 160 acres of corn ground and then planted it to soybeans. He ended up with succotash which ended it's use and the dealership.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2011 at 7:39pm
Well....my Howard got a bellyache this morning.  I tore the right side down, the bearing went out.  Now I am not sure what I need to fix it. Fortunately the shaft where the bearing seats is ok, but the nut came off the end and the threads and it are shot. I'm thinking if I can find an outer labrinth seal (the big round steel flange), and whatever the other seal in there was, I can snug up the nut and put some weld on it to keep it tight. I might just try to find a sealed bearing to put in there. Now I am back to my backup machine, kinda scary!  Anyone know where to find parts???
ALLIS EXPRESS!
This year:
captaindana View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote captaindana Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2011 at 5:29am
Ditto. I had a 6 footer for 25 years and ran it with a Case 970. They are indestructable!
Steve M C/IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve M C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2011 at 1:58pm
No one has mentioned the gear set in the drive box which lets you select tine speeds.Pretty cool units.
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnCO Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2011 at 12:38am
Eldon, there was a distributor in Ill I bought some parts from years ago.  Unfortunately I can't find the name in my files.  I suspect you can fix it with standard parts for a lot less $ and maybe a bit more work.
Rawleigh View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rawleigh Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2011 at 10:11am
Take the bearing to a bearing supply house and have them match it.  It will be a lot cheaper and you can get the latest bearing technology. See what happens when you brag on a piece of equipment!!  LOL!  Sorry for your problem.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2011 at 10:19am
Yes I am going to try to find a sealed bearing for it. I think the end just bolts on to the shaft, so I will probably just put a sealed bearing on and weld the nut back in place.  After that bearing goes, it will be time for a replacement end from a donor machine, or try to find a new one.
ALLIS EXPRESS!
This year:
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rawleigh Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2011 at 4:12pm
Or find a good machinist.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2011 at 8:17pm
Good machinists are expensive around here....and hard to find. I do have a buddy with a couple of CNC machining centers who says my money is no good there....may make a nice winter project for him.
ALLIS EXPRESS!
This year:
