OIL IN EXHAUST
woodbutch View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote woodbutch Quote  Post ReplyReply Direct Link To This Post Topic: OIL IN EXHAUST
    Posted: 01 Dec 2010 at 10:38pm
I have hd6e that starts easy and seems to run well accept for the white smoke and a lot of oil blowing out of exhaust. I have changed all filters and  oil ,removed air filter,checked oilcooler . There is signs of oil in radiator but no water in oil. I'm having a bad feeling about this dozer being a parts machine. How far into the engine do I have to go to find out what's wrong? Thanks for any guidance.
Steve M C/IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve M C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 01 Dec 2010 at 11:07pm
Oil in water is usually an oil cooler problem.White smoke and oily exhaust shouldn't be related to oil cooler problem.The dozer guys will have a better answer.
gemdozer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gemdozer Quote  Post ReplyReply Direct Link To This Post Posted: 02 Dec 2010 at 5:17am
You should have a head gasquet brook or head crack
somebody View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote somebody Quote  Post ReplyReply Direct Link To This Post Posted: 02 Dec 2010 at 6:40am
or broken oil ring
Kipn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kipn Quote  Post ReplyReply Direct Link To This Post Posted: 02 Dec 2010 at 9:53am
White smoke generally means that you are burning coolant. The raw oil in the exhust is telling me that there is alot of blow by from the rings.
1961 H3
Post Options Post Options   Thanks (0) Thanks(0)   Quote woodbutch Quote  Post ReplyReply Direct Link To This Post Posted: 02 Dec 2010 at 7:25pm
So  head gasket, pull head and fix, rings pull engine. I guess  better get started, the only heater out there  goes down about 5:30. Thanks guys!
dadsdozerhd5b View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dadsdozerhd5b Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2010 at 4:34pm
does it have a turbo? i do not think the hd6 did but if it does, look at the turbo seals first. any bubbles in the coolant when it is running? bubbles mean a head gasket leaking compression into the coolant. oil in the rad can only come from higher pressure oil system going into lower pressure coolant, ie oil cooler leaking. is it an allis engine or buda? using oil is one thing but blowing it out of the exhaust is obviously too much. you can put rings in it with the engine in  the dozer but if you have anyplace warmer than outside, that is the place to do it with winter coming. how does the wife feel about you working in the kitchen?
JMVMopar View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JMVMopar Quote  Post ReplyReply Direct Link To This Post Posted: 04 Dec 2010 at 10:58am
It might just be slobbering. The cylinders get glazed from running at little to no load for a long period of time. If it's running ok besides the oil slobbering (not overheating) I'd go out and work it hard for 3-4 hours (make sure you get it good and hot, but not overheat) and see what happens. Don't forget to check the oil level depending on how much it uses so you don't run it too low.
Working it hard can break the glaze off the cylinders and cure the slobbering. The white smoke could be a bad injector or low compression due to the glazed cylinders.
That's just what I would do if it were my machine.
This page was generated in 0.191 seconds.
