FActory correct Steerring wheels?
Orange Blood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Blood Quote  Post ReplyReply Direct Link To This Post Topic: FActory correct Steerring wheels?
    Posted: 30 Nov 2010 at 9:11pm
Who out there knows where to get the correct color scheme steering wheel for a D-21, the orriginal has cracked and seperated around the hub.  The wheel has creme colored spokes/center,  and a black wheel with creme accents in the grip depressions.  All of the aftermarket ones I see online, are all solid color but claim to be correct??   My D-17 has the same color scheme, and I will need one for it, when I do a restoration on it also.
Thanks in advance.
Anthony
Still in use:
BurtIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BurtIA Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2010 at 9:33pm
It started out as all cream colored, just worn down to the black. Same on the D17.
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2010 at 9:37pm
Burt is correct.  The cream colour wears off with use.  It should be all cream to start with.  Many vendors here have them available.
Jack(Ky) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jack(Ky) Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2010 at 10:25pm
I bought a new one but I did not like the finish so I sanded off the coating and made me up some base coat about what I thought the cream should be and then put several coats of clear over it. I really like the "slick" finish and I would recomend this method to really make a nice looking steering wheel.JP
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Blood Quote  Post ReplyReply Direct Link To This Post Posted: 01 Dec 2010 at 5:37am
Thanks guys,
I could have sworn that was factory, I will look again at the spokes where they meet the wheel.  Dad drove the thing off the rail car when new, I will have to see if he remembers that far back.
Sure makes it easier to get a new one.
Thanks again,
Still in use:
Good View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Good Quote  Post ReplyReply Direct Link To This Post Posted: 01 Dec 2010 at 7:25am
We tried to get a white steering wheel for our 17 but could only find the white ones with splines and our 57 D17 basicaly has the 45 steering wheel with a pin. Are all D21's the same in that way.
B212,716,two 314H's,WC,WD,D19,190XT
Butch(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Butch(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Dec 2010 at 7:45am
That is because only the later ones came with white steering wheels, about 1961 and when they changed the paint scheme they also changed the mountings to splined with a nut. I am sure you realize that the shape of the wheel is entirely differant too.  If you want a white wheel there are two ways to get there, paint on one that fits or a repro splined hub wheel and an afternoon spent with a mill and lathe.
Good View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Good Quote  Post ReplyReply Direct Link To This Post Posted: 01 Dec 2010 at 8:35am
Butch,no I didn't know they were different shapes,but we were going to get the short shaft that is held in the column that has splines. I just think the white wheel adds a little more class to the tractor.
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 01 Dec 2010 at 9:22am
There is one more steering wheel. The black bar grill D-10/12/14/17's had a black steering wheel with the diamond or Power steering logo in the center and mounted on a splined steering shaft. In 1961 those steering wheels became cream. I've always been able to find enough grey steering wheels from Gleaner E's to repaint and use on my D series restorations. The early D-14/17's with the orange diamond grill had the WD-45 style steering wheel with the pin.
Brian Ahart View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Ahart Quote  Post ReplyReply Direct Link To This Post Posted: 01 Dec 2010 at 7:31pm
Ditto Calvin.  One of our parts E's (w/ cab) had a near perfect original steering wheel that I used on my D12 III.  The steering gearbox bearings came in handy as well.
A-C Weight ID reference and other goodies at brianahart.net
This page was generated in 0.043 seconds.
