looking for metric bolts |
Post Reply ![]() |
Roger Mn ![]() Bronze Level ![]() Joined: 12 Sep 2009 Location: Preston Mn Points: 107 |
![]() ![]() ![]() ![]() ![]() Posted: 30 Nov 2010 at 6:53am |
Need 12 M20 X 2.00 X 65mm Roger
omahagreg ![]() Orange Level Access ![]() Joined: 11 Sep 2009 Location: Omaha, Nebraska Points: 2806 |
Don't know if you are close to a specialty bolt supply house. In Omaha, we have Nebraska/Iowa fastener. They had a 6" long metric bolt I needed, could even choose the hardness.
Greg Kroeker
1950 WD with wide front and Freeman trip loader |
JoeO(CMO) ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Cent Missouri Points: 2694 |
I think Lowes has Metric, not sure if they have your size/threads.
Fastenal also has, check their website.
Goose ![]() Orange Level ![]() ![]() Joined: 07 Oct 2009 Location: Melrose, Wis Points: 2471 |
I used to own a Yamaha motorcycle and snowmobile shop. We dealt mostly with metric. If you can't find any, let me know and I can probably get you some. Otherwise, try any Japanese motorcycle shop, such as Yamaha, Honda, Suzuki or Kawasaki shop. Perhaps a local foreign car dealer would have it, such as a Honda or Kia dealer.
Jeff Z. NY ![]() Orange Level ![]() Joined: 11 Sep 2009 Points: 7326 |
Just look in your yellow pages for a dealer under Bolts & Nuts and also under Fasteners-Industrial & Construction.
CTuckerNWIL ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: NW Illinois Points: 22822 |
Gerald J. ![]() Orange Level ![]() Joined: 12 Sep 2009 Location: Hamilton Co, IA Points: 5636 |
www.mcmaster.com has them in grade 8.8 and stainless steel but 2.5mm pitch, not 2mm pitch. The grade 8.8 is partly threaded, the two in stainless steel are fully threaded hex head. I didn't look for socket head. http://www.mcmaster.com/param/asp/psearch.asp?FAM=cap&FT_110=48195&FT_104=141&FT_1349=232268&FT_136=45180&FT_379=122672&FT_147=60655&FT_137=31621&FT_1464=61711&FT_182=47456&FT_2025=130285&FT_2234=257255&FT_2029=100006&ppe=3&session=desc=Screws;cap;110=48195;104=141;1349=232268;136=45180;M;I $2.99 each for grade 8.8
Or just bring up www.mcmaster.com. Click on bolts, click on hex head, click on metric, click on 20 mm diameter, click on 65mm length. The two stainless are quite a bit more costly that the zinc p]ated steel. They do have them in socket head also, but still 2.5 mm pitch. Fastenal has 1.5mm pitch with 1- 2 weeks delivery time, $5.70 to $15 each. 2.0 mm may be a tough size to find. Gerald J. |
What/ where are these being used? It might be easier to match from that angle.
putting loader brackets on a deutz DX130
Dale H. ECIL ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Paris, Il Points: 690 |
I needed a metric bolt for the draw bar on my 5030 a couple years ago, looked every where, finally tried Fastenal and they had it.
Allis Chalmers Museum, Paris, Il.http:// www.allischalmersmuseum.com 217-275-3428
Dave King ![]() Silver Level ![]() ![]() Joined: 24 Sep 2009 Location: OK Points: 97 |
John Deere usually carries metric, but Fastenal is better.
steve(ill) ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: illinois Points: 86029 |
you might want to check your thread pitch again.. 2.0 is not a standard size..
I was able to find the some bolts . thanks for the help Roger
Post Reply ![]() |
