wd45 Diesel ? looking for a narrow front end
mark-east-tn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mark-east-tn Quote  Post ReplyReply Direct Link To This Post Topic: wd45 Diesel ? looking for a narrow front end
    Posted: 29 Nov 2010 at 10:19pm
  If any one has a narrow frontend for a 45 D they want to sell or trade send me a pm thanks mark-east-tn
niel ev View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote niel ev Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2010 at 9:26am
Mark wish we were closer have a few setting up here could take your pick Niel
BennyLumpkin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BennyLumpkin Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2010 at 9:44am
The front should be the same off a gasser isnt it? If it is I have one but Im in PA
Central PA Allis Express
1934 WC254
1945 WF
1945 WC135755
1951 WD68085
1953 WD45-150217
1957 WD45D-230744D
B110
Sandknob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sandknob Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2010 at 11:50am
Benny,
Yes and No.
Yes if it a late 54 or later
No if it is an early 54 or earlier.
Late models had a cutout at the back of the pedistal for the crankshaft pulley to fit.
Adam
Rick View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2010 at 11:51am
From what I can tell by looking at them,the two narrow fronts are different. The one I have here is already spoken for though,sorry.  Rick
Post Options Post Options   Thanks (0) Thanks(0)   Quote BennyLumpkin Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2010 at 12:29pm
Thanks Sandknob....I really wasnt sure if they were the same or not.
1934 WC254
1945 WF
1945 WC135755
1951 WD68085
1953 WD45-150217
1957 WD45D-230744D
B110
JC-WI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2010 at 12:34pm
Mark look for a bolt on pedistol for a 45.  The wide front could be changed to narrow front with the bolt on tricycle pedistol. Commonly used with the mounted pickers when you had a WD45 with the wide front on it. Was no need to change out the front block
jordan watson View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jordan watson Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2010 at 6:03pm
Will one off a D15 work? I'm located in east alabama.
Post Options Post Options   Thanks (0) Thanks(0)   Quote mark-east-tn Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2010 at 6:11pm
I dont think so, I am looking for one for a 45 diesel  and would like to have one out of a diesel 45 or one of the bolt on narrow fronts.  Gas tractor narrow front wont work I have  a several of them . Just trying to keep it originall ...
j.w.freck View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote j.w.freck Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2010 at 7:37pm
have 2 here in texas,1 just came off a 45d and 1 off a gas.all you have to do is mill down the 2 aft webs...
