HD 6 E
bltfarms View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bltfarms Quote  Post ReplyReply Direct Link To This Post Topic: HD 6 E
    Posted: 29 Nov 2010 at 9:28pm
I just became the new owner of an hd6 e dozer. It has been setting for 3 years. It started ok and would move in forward and reverse but would not turn left or right. any suggestions as to what might be wrong?. the serial no is 9152 any ideas as to what year it was made? thanks larry
Steve M C/IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve M C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2010 at 10:38pm
the dozer guys will know but i think they are dry clutches and if so they likley are just "stuck" from sitting.they'll know how to free em up.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2010 at 10:40pm
Steering clutches frozen , need to get them to release, if fiber disc in clutches they are rusted to plates. Check bottom of case to make sure the holes through case are not plugged and water has set in case.  Pipe plug threads, clean case out well and then put about 5 gal of diesel in each side , run machine lightly using clutches to try to free up.
 If not you may have to pull full brake clutch drum and free manualy. At that time you might think of putting HD11 ceramic clutch plates into them.
Oh be sure to put plugs in holes when adding diesel as it tends to run out fast in not installed... LOL
Edited by Coke-in-MN - 29 Nov 2010 at 10:41pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote bltfarms Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2010 at 9:43am
Thanks Coke, do you happen to know the plug size? The dozer is not home yet and about a 20 min drive to work on it. Is there a site where I can find the year?  thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2010 at 12:00pm
believe they are 3/4" pipe plugs if memory is correct.
NickT(Ky) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NickT(Ky) Quote  Post ReplyReply Direct Link To This Post Posted: 12 Dec 2010 at 7:47pm
Anybody know the year of this? Larry is my brother. Nick
Ages Cat View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ages Cat Quote  Post ReplyReply Direct Link To This Post Posted: 12 Dec 2010 at 9:06pm
Serial number will identify year.
Post Options Post Options   Thanks (0) Thanks(0)   Quote bltfarms Quote  Post ReplyReply Direct Link To This Post Posted: 13 Dec 2010 at 10:14am
hd6e 9152 is the serial no. I have not been able to find out what year it is.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 13 Dec 2010 at 11:17am
1958 / srl# from 7948 to 10053
Sorry I missed your question on Srl # in your first post , but got around to it when I read your last post .. Rough getting old and not reading things completly
Edited by Coke-in-MN - 13 Dec 2010 at 2:03pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote bltfarms Quote  Post ReplyReply Direct Link To This Post Posted: 13 Dec 2010 at 1:39pm
Thanks Coke, we are lucky to have someone with your knowledge on this site. Larry
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 14 Dec 2010 at 4:00pm
mudder45  ( see his profile for e-mail address )
Hi guys, I have a complete AC 1967 HD6G for sale for parts . info can be seen in the forum classifides section page 2. Price is negotiable. you can click on the big and ugly to see a picture @ www.equipfind.com/heavyequipment/1967AllisChalmersHD6G
Saratoga NY area. I wish to sell it as one unit rather than part out. The old picture is from an old add I put out. Price, we'll talk ;-) Rick  ( mudder45 )
This page was generated in 0.906 seconds.
