sediment bulb |
Steve R
Joined: 12 Sep 2009 Location: Geneseo, IL Points: 127 |
Topic: sediment bulbPosted: 29 Nov 2010 at 2:19pm |
Any suggestions on how to get a very stuck sediment bulb off without breaking it? The guy I'm working for just got a JD A (I Know) and we have tried to get it off but it is really stuck.
Jeff Z. NY
Posted: 29 Nov 2010 at 2:29pm |
They are made of pretty thick glass and don't break that easy.
I know, I dropped them on a concrete floor and they bounce. LOL Wrap a dish towel around it and tap it with something like a rubber hammer or a large screw driver handle while you pull down on it. |
RyanTN
Joined: 12 Sep 2009 Location: Stewart Co, TN Points: 415 |
Posted: 29 Nov 2010 at 3:29pm |
Have you tried spraying it down (around the seal) with carb & choke cleaner?
jaybmiller
Joined: 12 Sep 2009 Location: Greensville,Ont Points: 24901 |
Posted: 29 Nov 2010 at 5:50pm |
Jeff you had much better luck than me! After I cleaned the one from my D-14, it slowly rolled off the bench and smashed into a zillon pieces! Said 'oh well', I'll just grab the one off the other D-14.OOPS, already been there,done that. 2 hour trip to the 'local TSC' and I bought TWO complete bowl assemblies.Nope, 2nd ones not on the second D-14...I've already misplaced it !!!!
tomdavison
Joined: 03 May 2010 Location: Canton, PA Points: 49 |
Posted: 29 Nov 2010 at 5:59pm |
I would heat it slightly with a hair dryer and then use the above suggestions.
Rick of HopeIN
Joined: 11 Sep 2009 Location: Hope, Indiana Points: 1329 |
Posted: 29 Nov 2010 at 6:53pm |
Usually I can't get them to stop leaking. I can't imagine one being stuck solid.
JohnCinMd
Joined: 11 Sep 2009 Location: Westminster, Md Points: 1442 |
Posted: 29 Nov 2010 at 7:08pm |
I soaked the whole assembly in a can of gas for a few days, then tapped it till it separated.
Jeff Z. NY
Posted: 29 Nov 2010 at 8:12pm |
jbmiller, Tractor Supply has plenty more.
Eldon (WA)
Joined: 11 Sep 2009 Location: Spokane, WA Points: 7765 |
Posted: 29 Nov 2010 at 8:26pm |
I think they are called sediment "bowls"......bulbs make me think of tulips....and spring....can't wait LOL!
ALLIS EXPRESS!
This year: |
AllisChalmers37
Joined: 11 Jul 2010 Location: London,KY Points: 1846 |
Posted: 29 Nov 2010 at 9:00pm |
PB Blaster. It unlocked the wheel bolts on my WC that had never been took off.
