rust bullet
Ed in TX View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ed in TX Quote  Post ReplyReply Direct Link To This Post Topic: rust bullet
    Posted: 28 Nov 2010 at 3:36pm
Anyone have any experience with this? I want to paint the inside of the rims before I mount up some tires. Anyone have a better plan? I don't have a way to blast them I was going to run a wire wheel over them and use this stuff.
AaronSEIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Posted: 28 Nov 2010 at 3:41pm
Never used that before.  Just did one of my WD rims.  Used a wire brush then 3 coats of Rustoleum primer.  I hope to notice an exterior leak before it eats through 3 thick coats of primer.
AaronSEIA
Adam in VA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Adam in VA Quote  Post ReplyReply Direct Link To This Post Posted: 28 Nov 2010 at 3:41pm
I haven't used this product myself, but I have seen it around before. I know a few people who use it. They have been using it on shed and barn roofs and not tractors. I haven't asked them exactly how well it works, but these guys are pretty particular so it must be alright for them to use it, at least on roofing.
Edited by Adam in VA - 28 Nov 2010 at 3:44pm
D21,D19,(2)D17,190XT,ED40, WD45,WC,B,25-40(Thresherman's Special),5030 plus buildings full of other stuff
427435 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 427435 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Nov 2010 at 4:15pm
I've had good luck with a product called Extend for neutralizing and coating rusty surfaces.  POR15 is also supposed to be good------a lot of old car restoration people use it.
Mark
GTH-L Simplicity
GBACBFan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GBACBFan Quote  Post ReplyReply Direct Link To This Post Posted: 28 Nov 2010 at 8:25pm
If you clean them good, either blasting or wire brush, wipe them down with denatured alcohol, and slather the inside with your favorite red oxide primer, they'll outlast both of us.
are genuine." - Mark Twain
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Nov 2010 at 9:43pm
I vote for sandblasting, priming and painting as well.
ALinIL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ALinIL Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2010 at 12:38pm
Ed - Have you ever thought of using cold-galv paint.  It's about $10/aerosol can.  You will need about 1.5 cans per wheel.  Just prep the rim and spray.  Check McMaster-Carr under zinc-rich paint. - AL
