Fluid Question
Pa'sOldA/C View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pa'sOldA/C Quote  Post ReplyReply Direct Link To This Post Topic: Fluid Question
    Posted: 27 Nov 2010 at 9:58pm
 I have been told I need to use Hytran in my D-19 Hyd. Then I was told no use Standard Hyd. Oil and then I was told Use 30 wieght Non-Det. I'm not sure what was used in it before I bought it. My D-17 I new what to use but the D-19 I have been told all kinds of things. So I figure I would get a straight answer from the forum.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 27 Nov 2010 at 10:05pm
Most all these old tractors used a straight weight Non detergent oil when new cause that is what they had. The hytran fluids are well suited for transmission, differential and hydraulics. I have used hytran in my WD45 for years. It is in everything but the engine and the final drives.
darrel in ND View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 28 Nov 2010 at 8:40am
I've used CaseIH hytran in mine for about 15 years
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 28 Nov 2010 at 12:02pm
HyTran has additives that capture moisture and turn to jelly keeping water from being circulated.
