WD hydraulics stick |
Embellem
Topic: WD hydraulics stickPosted: 27 Nov 2010 at 12:28pm |
I mounted the blade on the three point hitch (conversion) on my WD this morning and noticed a new problem. It lifts fine and the blade stays up in the hold position. The problem is that when I moved the lever all the way down on the quadrant to drop the blade, it still stayed up. I stood on the blade and it stayed up too. Then about 5-10 minutes later it finally dropped to the ground. Not very useful for plowing snow.
Any ideas why it would start sticking like that? It never did that before and I haven't changed or done anything to to the tractor since I last used the three point back in the spring. Thanks Matt |
jaybmiller
Joined: 12 Sep 2009 Location: Greensville,Ont Points: 25255 |
Posted: 27 Nov 2010 at 1:16pm |
Well....you did say you need it for plowing SNOW !!! LOL...
Murphy's Law..
Bound to be someone here who knows what knob to turn on which valve, I think there's 3 of them ????
My D-14 will do that if the traction boost is set too high, come to think of it.
Don(MO)
Joined: 12 Sep 2009 Location: Bates City MO. Points: 6862 |
Posted: 27 Nov 2010 at 10:39pm |
Well your tractor knows it got the wrong hitch on it. lol
Now on to making the hitch work, First you need to set the pump in the right setting in the pic below you can see "hold position" setting this is the one you need.
If the lift stays up and will not come down after you get it set; then screw the "D" in and back out the lift will drop fast so be careful.
Don
