Helllp! |
Post Reply ![]() |
LouSWPA ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: Clinton, Pa Points: 24458 |
![]() ![]() ![]() ![]() ![]() Posted: 27 Nov 2010 at 11:45am |
Ok,
any secrets to breaking the tire loose from the rim? I have a 4X4 ramped on it and drove -45 up on it......it's just mocking me! arrrgh! I sprayed a little Kroil on it hoping it will soak down through and break the grip. The kicker is, if this had of went flat in the field and I was counting on it to go very far it would have broke loose! 28x14.9
I am still confident of this;
I will see the goodness of the Lord in the land of the living. Wait for the Lord; be strong and take heart and wait for the Lord. Ps 27 |
JohnCinMd ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Westminster, Md Points: 1438 |
Drive on it? |
Dans 7080 ![]() Orange Level ![]() Joined: 05 Feb 2010 Points: 1146 |
Ive had luck with a "handyman jack" and the front axle of a big tractor. I tried a trailer tire using the trailer and it picked the trailer up ( 20+5 10ton gooseneck) but it broke loose before it picked up the front of the 7080.
Brian Jasper co. Ia ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Prairie City Ia Points: 10508 |
Yep, the secret is load it up and take it to the tire shop in town. It cost me $25 ea to get the rear tires removed on my D17. When I consider the aggravation that tires cause when you don't have the proper irons, it was money EXTREMELY well spent.
I have a cousin who runs a tire shop and he has a large slide hammer to break beads with.
MNLonnie ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Baxter MN Points: 4791 |
I use a splitting wedge that I welded to a handle, set the wedge on the tire and drive it behind the rim with a BFH, it's worked everytime for me so far. I used to try the drive on them trick but had some that it didn't work on.
MUM FARMER ![]() Silver Level ![]() Joined: 12 Sep 2009 Points: 95 |
pour coke around the bead and go have lunch then give it a try
Eldon (WA) ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Spokane, WA Points: 7765 |
Don't you have a crawler with a bucket on the front? I use my backhoe bucket, sometimes I have to bridge the tractor with the hoe, but haven't had one not break loose with that method. Smaller tires I use one fork and the skid loader. |
ALLIS EXPRESS!
This year: |
JW in MO ![]() Orange Level ![]() ![]() Joined: 16 Feb 2010 Location: South KC Area Points: 2633 |
I have done as you with a WD45 or the front gang of a heavy disc, then used a big pry or rock breaker to break them loose. Beat on one section, move 6-8 inches and repeat and it broke loose. Kroil makes a big difference. Now I use the bucket on the bobcat
darrel in ND ![]() Orange Level ![]() ![]() Joined: 22 Nov 2009 Location: Hebron, ND Points: 8657 |
MUM FARMER, if coke breaks beads, what does it do to your innards when you drink the stuff? Darrel
Bob-Maine ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Central Maine Points: 922 |
I use Dans 7080 method. I put a 12 ton hydraulic jack base on the tire, near the rim as possible, with the upper part of the jack up against something HEAVY above it. Pump the jack and eventually the bead breaks loose. May have to move it around to a few more spots, then eventaully the whole side comes loose. Hope this helps. Bob@allisdowneast
wfmurray ![]() Orange Level ![]() Joined: 13 Sep 2009 Location: Bostic NC Points: 1225 |
If tire is no good . Cut hole in tire with sawall and cut down to rim then use good thin cold chisel to cut wire.Then just peel it off rim. It worked for me. |
GBACBFan ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Green Bay WI Points: 2662 |
Use a Bead Cheetah. It's foolproof.
are genuine." - Mark Twain |
CTuckerNWIL ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: NW Illinois Points: 22823 |
Lou, I was gonna suggest the splitting wedge but Lonnie beat me to it. With the tractor ramped up on the tire, then hit it with the splitting wedge. Just don't get your toes under anything.When I used the tractors back wheel I didn't use a ramp, just drive the tractor wheel right on the sidewall as close to the rim as you can.
Edited by CTuckerNWIL - 27 Nov 2010 at 5:17pm |
David Maddux ![]() Orange Level ![]() Joined: 13 Sep 2009 Points: 2526 |
If you are going to be messing with the old tractors and think you have to do the tires, spend the money on the bead cheetah like GBACG says. I have one and it has paid for itself many times.
Steve in NJ ![]() Orange Level Access ![]() ![]() Joined: 12 Sep 2009 Location: Andover, NJ Points: 11908 |
I'm wit' Brian. Take it to the tire shop. It ain't worth the aggravation. That's what I do also because I don't have the proper tools, nor the backside to do that kinda work. Drop em' off, pick em' up later. Backside is still in good shape and ain't sore.......
Steve@B&B |
Well guys, Thanks for all the input. I did think of the HD5G, but it is torn apart at the moment. I really liked Brians idea, but in the near future (12 mo's) or so, I'll have about 7-8 of these to do (removing the tires to fix the wheels) and, in most cases the tire is salvageable. SOOOO, I next checked the prices on the "Cheeta". A little more than I have to spend right now, but, I do have a fire wrench and MIG, and a 10 ton porta power so I think maybe I'll use the pics of the Cheeta, and some other beadbusters I saw on line as inspiration see what I can come up with in the REDNECK ENGINEERING DEPT
JC-WI ![]() Orange Level Access ![]() Joined: 11 Sep 2009 Location: wisconsin Points: 33901 |
Hey Lou, when you get your redneck art form made, put a pic on here.
Theres a device that you clamp on the rim and turn the bolt and it pushes the bead off... problem is when the rim is tender, it tweaks it out of shape.
Got a slide hammer with a spade on the end that I use to bust beads on good tires but use angle grinder on old tires that are no good.
ChuckLuedtkeSEWI ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Jackson, WI Points: 1826 |
I use to use a 2 x 12 ramped up and then drive my pickup on it all the way to the edge of the rim, and the weight would break the bead. If they are really stubborn, I use a 6' bar and beat next to the 2 x 12 and will break loose. Sometimes, I have left the truck on there for a while and it works. Now I use my ramp for my trailer as they are loose and I can't break them like I did with a 2 x 12 every now and then. I even helped my dad with some new tires for his Simplicity tractor, and after swearing at them for a while, I forgot that I had the ramp in the back of my truck. Went up and did one side, flipped it over and did the other side in 5 minutes. I have never had one that I couldn't pop loose with that method, and now that I have a F250 which is bigger(and heavier) then my other truck it works even better. The key is to get the ramp as close to the bead without touching it, so it puts as much force on the tire as possible. I use to take them in, but I am cheap so I figured if I can teach myself to do it, I can save some money for more tractors!!
Chalmersbob ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Pennsylvania Points: 2122 |
Lou, I use 2 crow bars, or a chisel and a crow bar. I drive i crow bar between the tire and the rim, until it hits the rim. Then drive the second one in upside down, ang hammer on the curved part right near the rim. move it 2" and hammer some more until it falls off the rim. I can remove a tire in 20 minutes with this method.
A neighbor, who is a mechanic, couldn't break a front tire from his B. He tried his loader, a sledge hammer, and took it to another neighbor, but could brek the bead. I used my method and had it off in a few minutes. Bob
ScooterBuck ![]() Bronze Level ![]() ![]() Joined: 19 Oct 2009 Points: 76 |
Hey Lou the Cheeta is used to set the bead onto the rim when installing the tire, not breaking the bead off of the rim when removing the tire. There is a product call Bead Breaker that works great! There is also a tire sledge that has a wedge shape on one side much like a tool someone described above. A good but slightly dangerous sub for the cheeta is staring fluid and a match;) |
Lonn ![]() Orange Level ![]() ![]() Joined: 16 Sep 2009 Location: Назарово,Russia Points: 29792 |
You get that apart yet Lou? Brother had some old 13x24 WC tires and wheels that he wanted to change and after beating on them a while he just had the local tire guy change them. They were the really old tread design and had been on awhile. Even the tire guy struggled some.
Wink I am a Russian Bot |
My bad. I was referencing the Bead Cheata, Speeco P/N 05500. The bead Cheetah (with an "h") is used as ScooterBuck has described.
Well, there is, I discovered, a bead breaker called a Cheata, also, which is what I assumed you guys was refering to. Anyhow, I won't get back to it till next week.
What I am envisioning is a WD side rail laying on the ground with a 2-3 foot pipe welded on sticking up, with a lever arm pivoting off the top of. The lever arm will have a chisel pivoting off of it. The end of the lever arm will be "pulled" down with a retractor cylinder and the porta power
Awe...just wait until you get the crawler back up and runnin.....ain't no tire that will stand up to that baby. More efficient use of your time, too!
ALLIS EXPRESS!
This year: |
Dick L ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: Edon Ohio Points: 5087 |
You can block the tire up under a heavy trailer. truck frame and use a hydraulic jack at the edge of the rim on the tire. I have put some under the tongue of my big trailer and jacked on them. hard work but you can get it to push away.
Hurst ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Midway, Ky Points: 1213 |
Let the air out of it :) lol. To be honest, I spent over an hour trying to break the beads on some 18.4-34s with a bobcat, sledge and wedge, truck, etc in the 90+ degree heat this summer only to remember I had only taken the valve stem out of one of the tires.... I found that I really needed the edge of a bucket to get the bead broken, as driving on it would not get pressure close enough to the bead.
Hurst |
1979 Allis Chalmers 7000
5800 Hours |
Post Reply ![]() |
