I need another tractor
BiG210 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BiG210 Quote  Post ReplyReply Direct Link To This Post Topic: I need another tractor
    Posted: 25 Nov 2010 at 4:22pm
I need a tractor for the planter and sprayer is a d17 to small for a 6row planter.
Steve M C/IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve M C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 25 Nov 2010 at 5:56pm
Pull a JD 7000 6-30 with a WD45.Two 150lb weights and no fluid(but was nicer with fliud).Flat gound/no problem.
Dave in il View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave in il Quote  Post ReplyReply Direct Link To This Post Posted: 25 Nov 2010 at 6:39pm
A 6 row 30 on a D17 would be no problem unless it was no till or had starter fertilizer and even then would probabley be fine unless you have alot of hills.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 26 Nov 2010 at 6:35am
Years ago, I knew of two fellas who both pulled 8 row wide (38") JD 7000 planters with D17 series 4's in fairly rolling ground. Both had rear wheel dual tires and were in great shape mechanically. Both said they could only run high 2nd gear at wide open throttle. Pulled hard at times, but not as hard as a plow. After many years of this, they both went on to 185's and remarked how much cheaper the diesel was to run.
