help
LionelinKY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LionelinKY Quote  Post ReplyReply Direct Link To This Post Topic: help
    Posted: 24 Nov 2010 at 8:09pm
Well, I got a picture up there but it doesn't leave me any room for text or anything else. I was hoping to type some text and insert a few images for all to see. What am I doing wrong? How do I resize pic to post smaller? Thanks-Lionel
roughstock View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote roughstock Quote  Post ReplyReply Direct Link To This Post Posted: 24 Nov 2010 at 8:25pm
What I do, is after uploading an image, I change the height and width to 33% of the default size. Also type your message first and then insert image. I hope this is the help you're looking for.
Brian
Jeff(WD45-SATX-TN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff(WD45-SATX-TN) Quote  Post ReplyReply Direct Link To This Post Posted: 24 Nov 2010 at 8:27pm
Lionel,
Before I insert a picture I hit the retun key a few times. Or, type your text first then hit the return key to give some space between your text. If you type after a picture, once it is in the field hit return key and type away.
Thats how I do it. Hope that helps.
Jeff
1954 WD45 NF "Iron Tater"
