715 backhoe loader question
ndhoser View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ndhoser Quote  Post ReplyReply Direct Link To This Post Topic: 715 backhoe loader question
    Posted: 23 Nov 2010 at 3:33pm
I have a 715 that lost the rollback on the front end loader. Everything else works, lift, lower, dump, even the self level ( as long as I'm raising. As soon as I let go of the lever the bucket dumps). The serial number is 1708. It uses a Gresen Valve that my manual has a description of, but no diagrams. Would anyone have any info on this valve? it would be greatly appreciated.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2010 at 5:10pm
The valve body should be single lever control with side to side being bucket, fwd. back being lift and lower. Somehow your linkage is off and not allowing valve body to remain in neutral position for bucket.
 Raise the floor plates and check all the linkage for proper movement .
Dave A View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave A Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2010 at 6:13pm
If it is not a linkage. Check relief valves. Think the bucket and loader run two differant PSI.
Play the game for more than you can afford to lose... only then will you learn the game.
Winston Churchill
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave A Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2010 at 6:16pm
Hey I got a question for the AC loader guys. What keeps the bucket level when lifting. When raising the loader the bucket rams slowly extend
Winston Churchill
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2010 at 8:10pm
The linkage is set to allow the bucket to curl to keep the load from spilling and from dumping over the top side also . You will notice there is a rod on side of loader arm which attaches to bucket linkage that gives you level position of bucket and can be gauged for dig positioning. Not a real self leveling unit but close.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ndhoser Quote  Post ReplyReply Direct Link To This Post Posted: 24 Nov 2010 at 9:58am
Dave,
In this particular unit the oil from the rod end of the lift cylinders is directed through the self leveling section of the valve to the barrel ends of the bucket cylinders and the rod end of the bucket cylinders flow back through the self leveling section to the sump, hence my desire for the diagrams.
Coke,
I've checked the linkage and it's ok. I've torn the valve apart and checked for stuck spools and lift checks and can't find anything there either. I removed the lines from the barrel end of the bucket cylinders to see if they were bad and got no oil to come out when I tried to roll it back. I have good down force on the bucket so I have a hard time believing it is a cylinder problem, but I'm going to tear into them for lack of knowing what else to do. This is definately a stumper for me!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 24 Nov 2010 at 10:21am
Are you sure then there isnt a problem with the cylinders ? I did not figure in when you let lever go to neutral the bucket uncurled.
 I would look close at the cylinders for internal leakage in one or both. I had a Pettybone loaded that did the same thing and one piston seal was bad allowing the oil past to the dump side.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ndhoser Quote  Post ReplyReply Direct Link To This Post Posted: 26 Dec 2010 at 3:54pm
I finally got around to putting seal kits in my bucket cylinders. Didn't help. It has to be something in the valve. I don't really want to change all the plumbing in order to fit a new valve in there, but I don't think I have any alternatives.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2010 at 8:30pm
Unsure if that has the regenerative circuit in that valve body also to bypass oil back to unload side of cylinder , you would have to check the manual. Just seems strange there would be that much leakage in valve body.
D-17_Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote D-17_Dave Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2010 at 10:44pm
You stated that you repacked the bucket cylinders. Did you repack the boom cylinders. I don't know anything about this tractor but with the description of the circuit described above if the boom cylinders are blown it could cause the same effect. Just a thought.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ndhoser Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2011 at 9:37am
Here is what the book says about the bucket section:
The bucket section is a 4-way section with the "A" work port connected to the barrel ends of the bucket cylinders (Figure I). The bucket cylinders are connected in parallel. The bucket section spool has 3 positions and is spring centered to neutral. Pushing the spool in, (Figure J) directs oil past the lift check and out the "A" port to extend the cylinder rods and dump the bucket. A floating check between sections prevents oil flow back into the level section work port. An anti-cavitation ball check, located in the lift checkplug assembly, prevents the oil from flowing back into the work port of the self-leveling section. An anti-cavitation ball check located in the lift check plug assembly, prevents bucket cylinder cavitation, when the bucket "dump" over center, by allowing the oil to flow from the sump passage into the "A" port cavity.
Pulling the bucket section spool out, (Figure K) delivers oil past the lift check and out the "B" work port to retract the bucket cylinder rods and "roll-back" the bucket.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2011 at 10:16am
Then it sounds like that check valve(ball) has a problem in its seating or sealing the regen port.
This page was generated in 0.176 seconds.
