Pitman parts on a G sickle mower
JW in MO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JW in MO Quote  Post ReplyReply Direct Link To This Post Topic: Pitman parts on a G sickle mower
    Posted: 23 Nov 2010 at 10:33am
I've got a sickle mower with a broken pitman arm and the problem is the end that attaches to the sickle is missing.  According to my book it is a #4 mower however Agco parts books don't show a #4 mower, they show a 3,5 etc..  Would like to get the needed parts to get everything up and running again.
Creek Jenkins View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Creek Jenkins Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2010 at 5:38pm
JW - I had the same problemo.  I looked thru the parts pages and the #3 or #5 (whichever is used on the B) mower pitman parts looked pretty much the same as the #4 parts.  If I remember right, the #3 and #5 even use the same pitman parts, it might be the stick is different length.  Anyway I called our local (4 hours away) AGCO dealer and he agreed that it looked like the parts were the same.  I ordered the sickle end parts - clamp, frame, spring, as well as the tool.  They worked fine on my #4, they looked exactly the same as the old parts  (except not broke or worn out).  This year the other end of the pitman wore out, but I was lucky enough to stumble onto a #4 mower at an auction and I picked it up pretty reasonably and scavenged the parts.  I think Jim at OK parts told me once he had a few B mowers he would part out, you might give him a call.  For the stick I just bought a univeral pitman stick at the local fleet farm and cut / drilled it to match the old broken one.  Only not broken.
Lemme know if you have qwestions.
cheers,
Creek
Dusty MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2010 at 7:30pm
JM, I have a parts book with drawings and parts #'s. PM me your e-mail address I'll send you a scan.
Dusty
Pl2cooper@yahoo.com View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pl2cooper@yahoo.com Quote  Post ReplyReply Direct Link To This Post Posted: 19 Mar 2020 at 5:18pm
Text me 337 378 5152 on some way to get a diagram of the pitman arm for #4 all is chalmber mower
Thanks for any help
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 19 Mar 2020 at 5:38pm
Might have some of the parts your looking for.
Edited by Mikez - 19 Mar 2020 at 5:48pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 19 Mar 2020 at 7:48pm
Yes the B/C, #3,, #4 & #5 all use the same pitman parts. Only the frames are different.
This page was generated in 0.184 seconds.
