How light can a 7030 get ?
DarrylinWA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DarrylinWA Quote  Post ReplyReply Direct Link To This Post Topic: How light can a 7030 get ?
    Posted: 22 Nov 2010 at 11:35pm
Just had a crazy thought on how light can I get a 7030 ? I have press steel rear rims, pull off the cab with open station fenders, take off 3 point and some parts. Get 9000 lbs easy ? 10,000 easy. Just looking for some ideas. Not going crazy on it. Getting this tractor cheap and looking for opinions good and bad.
Thanks in advanced,
Darryl
B 10 Custom. Serial # 1001 D21, First D21 built 69 #4498 and Last D 21 Built #4609. 1946 MM UTU. And 2000, 2005 Pete's. AC custom Hauling.
Dans 7080 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dans 7080 Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2010 at 12:31am
I have a 7060 that i use, Cab, long axles, cast centers, 18.4-38 loaded, 14L-16.1s, 2 inner wheel weights on each side, full set in front, It weighs 17060 with about half tank of fuel. Figuring theres about 3000lbs of weight, loaded tires add 1420lbs per tire (i think il check tomorrow) cast centers are around 700 per side. That doenst include the cab, 3-pt, or anything else youl take off. So Id say 10000 easy prolly 9000 wouldnt be hard either
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2010 at 7:22am
Originally posted by zhang00 zhang00 wrote:
I also have a 7060,ineffective use them, how to deal with this?
Say again
Wink
I am a Russian Bot
Charlie175 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2010 at 8:39am
He is a spammer
Charlie
