Is this part available. SC Blade? |
rasman57
Topic: Is this part available. SC Blade?Posted: 22 Nov 2010 at 6:00pm |
My old Snap Couple Blade is getting restored. Wondering if anyone can give me a resource to locate this bolt block? Mine has two broken bolts long rusted in as well as two that are stripped out. Before I get too excited and go to working, I am hoping someone maybe has one.
rasman57
Posted: 22 Nov 2010 at 6:07pm |
T
Allen Dilg
Posted: 22 Nov 2010 at 8:22pm |
There are 3 ways, first drill and extract, second weld a nut to the bolt, and the easy way is to take a pencil and draw it OUT!! couldn't resist. Good luck
FloydKS
Joined: 12 Sep 2009 Location: S E Kansas Points: 8466 |
Posted: 22 Nov 2010 at 8:40pm |
I did kinda as has been sugested with mine...that is replace the threaded area with several nuts...ya gotta cut away the threads and "space" the bolts with the part with the holes in it ....I actually had a professional welder do it even though I weld...it has been too long and I don't have a welder that would penetrate.
Unit3
Posted: 22 Nov 2010 at 9:16pm |
Allen (Draw it out) LOL That is funny right there. There was a man parting one out on the old site. Can't remember the name maybe Andy from N or S Carolina. I bought a handwheel and angle plate from his blade. |
Doug northern IL
Joined: 12 Sep 2009 Location: northern IL Points: 201 |
Posted: 22 Nov 2010 at 10:08pm |
Would helicoil work, just wondering
jaybmiller
Joined: 12 Sep 2009 Location: Greensville,Ont Points: 24902 |
Posted: 22 Nov 2010 at 10:24pm |
You might get lucky and try electrolisis(sp) to 'draw' the rust out of the threads. I've done it a few times seems about a 50-50 deal. Heck ,let it cook overnight...can't hurt anything !!
rasman57
Posted: 23 Nov 2010 at 9:48am |
If it was just broken bolts and rust, I would be dreading the project. The additional mess of stripped threads means drilling out and tapping unless the helicoil is used. That is getting busy! I am going to work on the rest of the blade assembly and if a decent block does not turn up for sale, I'll have a project for the machine shop. That is a big drill and tap.
sks72107
Joined: 30 Sep 2010 Location: Logansport, IN Points: 441 |
Posted: 23 Nov 2010 at 1:12pm |
Wow, im sure my dad would make short work of this. Honestly this looks easy compared to having to fix %80 of the broken bolts that hold the side panels(under gas tank) on my d17. All are broken flush with frame, no i didnt do it. But i sure do cringe when i think about when it comes time to fix these. Good luck, perhaps a little Kroil penetrating oil. I think you can fix without welding. $0.02
Shannon
NICKMI
Joined: 15 Sep 2009 Location: Greenville Points: 534 |
Posted: 23 Nov 2010 at 8:13pm |
you could always just weld it together thats what most ppl did when they got tired of fixing the bolts weld will be stronger so it wont break as easily just my two cents NICKMI |
Steve M C/IL
Joined: 01 Jul 2010 Location: shelbyville IL Points: 691 |
Posted: 23 Nov 2010 at 9:50pm |
And last but not least,put studs in rather than bolts.I have studs with fine thread on the outer end.Loctite the inner.Have nylock nut outside. Mine have never worked loose.
Brian Jasper co. Ia
Joined: 11 Sep 2009 Location: Prairie City Ia Points: 10508 |
Posted: 24 Nov 2010 at 4:48pm |
Take it off and take it to a machine shop. There's one close to me that can fabricate or repair just about anything. Something like that would be a quick and easy fix in a mill. A couple plunge cuts and and tap out the remains.
