H3 jumps out of 3rd gear?
chevytaHOE5674 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote chevytaHOE5674 Quote  Post ReplyReply Direct Link To This Post Topic: H3 jumps out of 3rd gear?
    Posted: 21 Nov 2010 at 9:29am
My H3 with shuttle clutch has started jumping out of third gear very frequently. Is this a common issue with a common fix? Or do I just start tearing the shifter apart and seeing what is worn? Thanks
Kipn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kipn Quote  Post ReplyReply Direct Link To This Post Posted: 21 Nov 2010 at 12:15pm
Probabaly the same problem most D15 tractors have with 3rd gear. It's inside the tranny. The actual gear gets worn. I have heard that it's an expensive fix. Search on the tractor page for popping out of 3rd gear. Lotsa posts.
1961 H3
Post Options Post Options   Thanks (0) Thanks(0)   Quote chevytaHOE5674 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Nov 2010 at 4:07pm
That's what I was fearing... Hmmmm
Looks like to check anything out I have to take the shifter cover off the side of the tranny. Which from the book looks like it is behind the steering brake and final drive. Looks like it will have to wait until spring.
Edited by chevytaHOE5674 - 21 Nov 2010 at 4:35pm
Jack(Ky) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jack(Ky) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Nov 2010 at 5:09pm
Is it popping out under power or going down hill. If it just falling out going down hill you can fix it pretty easy.JP
Post Options Post Options   Thanks (0) Thanks(0)   Quote chevytaHOE5674 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Nov 2010 at 5:33pm
It is popping out under power(just driving not dozing) on level ground. But if you run it for a little bit in 4th before going to 3rd it seems to hold in 3rd better.
This page was generated in 0.410 seconds.
