Leaking Radiator Hose
Osage_Orange View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Osage_Orange Quote  Post ReplyReply Direct Link To This Post Topic: Leaking Radiator Hose
    Posted: 21 Nov 2010 at 7:24am
What do you fellas recommend as a sealer between the radiator hose (lower) and radiator.  Was thinking of just using grease, but don't know if it will attack the hose.  It leaks sometimes when the weather changes (not while running).  The hose is almost new.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 21 Nov 2010 at 8:12am
You could try two gear clamps,one pointing north, the other south. I do that on all my well and swimming pool hoses.The cost is next to nothing compared to the 'have to do it again' wasted time !
Dusty MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 21 Nov 2010 at 8:17am
I like to use plumbers pipe dope.
Dusty
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 21 Nov 2010 at 2:10pm
Constant tension hose clamps like what's used on late model cars. (spring clamps) I would think long term grease would attack the hose.
Adam Stratton View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Adam Stratton Quote  Post ReplyReply Direct Link To This Post Posted: 21 Nov 2010 at 8:40pm
I use the black pemetex gasket maker.  You can buy the bottles at any O'Reilly or auto parts store.  It makes a real mess on your hands, but it is slick enough to help hoses slide, but forms a good bond with the hose and helps it stay put when you are done.  Good luck!
JoeM(GA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeM(GA) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Nov 2010 at 9:22pm
Allis Express North Georgia
41 WC,48 UC Cane,7-G's,
Ford 345C TLB
Clay View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Clay Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2010 at 8:28am
Permatex® Indian Head® Gasket Shellac
