D21 air cleaner asembly
whatscooking View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote whatscooking Quote  Post ReplyReply Direct Link To This Post Topic: D21 air cleaner asembly
    Posted: 08 Apr 2026 at 11:30am
The cleaner that is in my D21 obviously isn't correct. Anybody have one? I have one that is too large to trade.
Post Options Post Options   Thanks (0) Thanks(0)   Quote whatscooking Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 2026 at 5:35pm
Think 70253653 is the part number. By chance is it anywhere close to a 190?
Don Jr NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don Jr NY Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2026 at 4:27am
A 190 air cleaner is the same size as a 200. The one in a D-21 is bigger and the same as the one in a 220.
d17brown View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote d17brown Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2026 at 8:48am
Ar you needing the filter canister
phil
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2026 at 11:31am
I believe the turbocharged D-21's got a bigger air cleaner (70253653) and it was the same as the 210/220 tractors. Older series 1 D-21's that got the factory field installed turbocharger "KIT" would have had this newer/larger air cleaner installed at the same time the turbo was added.
Post Options Post Options   Thanks (0) Thanks(0)   Quote whatscooking Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2026 at 12:02pm
The air cleaner in there now is so big there is only about 7 inches to drop the dust bowl out, no way the filter is comming out.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2026 at 12:49pm
Have you tried it? It's tight on my 220 but will cock and come out.
im4racin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote im4racin Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2026 at 12:51pm
That’s the way na 21s were
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2026 at 2:48pm
Sounds like you have the right filter assembly.  It looks like a tight fit, but the filter will come out.
Post Options Post Options   Thanks (0) Thanks(0)   Quote whatscooking Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2026 at 4:17pm
I guess I dont know what I want. Have the tractor at a shop to split for transmission seals, ow and a couple other things.
Lynn Marshall View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2026 at 10:06pm
I think that there were three different 190 air filter configurations.
Post Options Post Options   Thanks (0) Thanks(0)   Quote whatscooking Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2026 at 4:00am
Can anyone take their grill off and take a picture of their Series two air cleaner?
Post Options Post Options   Thanks (0) Thanks(0)   Quote whatscooking Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2026 at 8:59am
I got a call about one. Really would help to see what a Series 2 setup looks l8ke.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2026 at 3:29pm
About 6.5 inches from bottom of cup to front surround on my 220
Post Options Post Options   Thanks (0) Thanks(0)   Quote whatscooking Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2026 at 4:53pm
And the filter comes out? I guess that is what iam seeing
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2026 at 4:58pm
You need to actually try it before saying it won't work. The filter is smaller in diameter than the can so it has room to tilt and come out.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2026 at 9:06pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2026 at 9:42pm
Mike do you actually have that complete housing?
