Old member. New toy
DREAM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DREAM Quote  Post ReplyReply Direct Link To This Post Topic: Old member. New toy
    Posted: 07 Apr 2026 at 8:02pm
Hey everybody, long time no type.
Lets just say life got REALLY busy for me for awhile. Still have my 46 C.
Just aquired a bucket list(for me) tractor completely by chance.
Gonna see if i can remember how to get pics on here, and then ive got a few questions...
First question though is "hows everybody been?"
I didn't do it! It was a short, fat, tall, skinny guy that looked like me!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DREAM Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2026 at 8:13pm
Ok, i cant remember how to do the pictures. Used to use dropbox, but cant remember how.
Anyway, i found myself a fairly clean, mostly complete 1949 AC model G.
Has hydraulic lift front and rear. Has headlight still in place. Came with a full set of AC cultivators. Also came with what i believe to be an Athens brand disc plow, and a Bush hog brand belly mower.
Ive just started tinkering with it, and the starter is going to need some help. Looks like it may have been hit with 12 volts a few times. Im still not sure, but the battery that came in it "looks" like a 12 volt. Has 6 water holes. Tractor has also jad a Ford 12 volt coil installed, but still has tje 6 volt Delco remy gemerator and some questionable wiring. Still has tje cutout and 2 position charge selector switch that seem to still ne doing thimgs. Tje genny field lead has been spliced and grounded to the dash panel. Not sure whats up with that.
Im going to check to see if my local guy is still in business doing starter/generator work to see if he can get brushes for tje starter, clean up the commutator, and see if starter/generator are burned up. Generator field winding ohms out at around 3 ohms, so?
Any help is greatly appreciated.
Les Kerf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2026 at 8:51pm
Originally posted by DREAM DREAM wrote:
... genny field lead has been spliced and grounded to the dash panel. Not sure whats up with that.
Apparently they converted to 12 volts and instead of doing a proper conversion they just full-fielded the generator to force it to charge the 12 volt battery.
... Generator field winding ohms out at around 3 ohms, so?...
3 Ohms is right in the ballpark
Post Options Post Options   Thanks (0) Thanks(0)   Quote DREAM Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2026 at 9:09pm
Thanks for that! Sounds like they just did a budget 12 volt conversion.
Im not sure what the right way forward is on that.
I know the starter will handle 12 volts, as long as its not spun over for long periods of time. My C jas only had a 12 volt battery as long as ibe had, and it does fine. I cut the genny leads and jist charge the battery if i need to. It has a mag, so no need to give power to ignition.
I just dont want to burn up that generator if its still good, and i need a way to power the ignition on the G, since it has a distributer.
What about going to an 8 volt battery? Maybe a little more "kick". Manual says the system is good for 6 to 8 volts.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DREAM Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2026 at 9:12pm
I really just need to get the starter rehabbed and then see what kind of shape the engine/trams/hydraulics are in before i get too deep.
Gas tank looks like new on the inside BTW, as does the radiator, so small wins there.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2026 at 11:17pm
Has been a spell since I seen your name on a post. Good to see you're still on top of the dirt.
darrel in ND View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 2026 at 5:12am
Welcome back to the forum. Good to hear from you again. My latest acquisition was also a G. Wasn't exactly on my dream bucket list, but it came along and I thought that I had to have it. It'll be a "work in progress" for quite some time, I am sure.
Darrel
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 2026 at 1:56pm
There is nothing technically wrong with converting to 8 Volts; the only drawbacks are  the cost and relatively low availability of 8 Volt batteries, and the hassle of charging/jumping a dead battery.
My late Father-in-law ran his WD on 8 Volts for decades.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DREAM Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 2026 at 7:35pm
Good point about the charging a dead battery part. Hadnt thought of that. Ive got a 6/12 volt charger, so thanks for that.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DREAM Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 2026 at 7:36pm
You too Steve! Hope everyone is well up your way.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DREAM Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 2026 at 7:38pm
Thats exactly what happened to me Darrel. Wasnt planning on buying another tractor at all. Already too many projects going on, BUT like you said...just couldnt pass it up.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubert (Ga)engine7 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2026 at 7:54am
Good to see you back. I had been wondering what happened to you. That little G is a nice tractor with the implements you have. I would consider changing it to a 12 volt system with a rebuilt generator or alternator with avoltage regulator and new coil.
Have you tried Booty’s in Royston lately? The last time I was there a year or two back the food wasn’t that great.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DREAM Quote  Post ReplyReply Direct Link To This Post Posted: 9 hours 55 minutes ago at 6:31pm
Nice to hear from you too! Hope yall are doing well.
TBH, i havent EVER eaten at Bootys. Leatherwood and Swamp guinea back in the early 90s when my grandfather was still around. Red Minnow used to be good too, before it burned down. They had another one here in Elberton. It was NOT good the one time i ate there.
As far as keeping this on topic, no new developements on the G yet. Ill get in touch with a local guy to see if he can do anything with this starter some time next week. Was out buying McCulloch chainsaws all day today...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 9 hours 28 minutes ago at 6:58pm
... Was out buying McCulloch chainsaws all day today...
Cool! Cool
I grew up running McCulloch saws
