190XT New "Old" Alternator not charging
MadCow View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MadCow Quote  Post ReplyReply Direct Link To This Post Topic: 190XT New "Old" Alternator not charging
    Posted: 05 Apr 2026 at 5:46pm
My 190xt had a new one wire alternator put on it. Since my distro tach drive is stripped I opted to go back to the alternator tach drive. Bought the old style which I guess is actually the second or new style? Whatever. Bought the 3 wire tach drive alternator from DJs. But I cannot get the alternator to charge. I'm 99% sure the wires are making solid connections on everything that is connected, and I *think* everything is wired to match the service manual. Problem is the service manual only shows for the delcotron not for an alternator?
I don't hear or see any clicking from the voltage regulator. How is this thing supposed to be wired up? How can I test the voltage regulator? The service manual read like gobbldegoock.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2026 at 6:29pm
To me that looks like an alternator with built in voltage regulator. A '3 wire' unit and not 'one wire'.
For me
 a 'one wire' unit ONLY has the big , high current wire
 a 3 wire has, high current, a sense line and an ign wire.
Either of which do NOT require that external  regulator
Post Options Post Options   Thanks (0) Thanks(0)   Quote MadCow Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2026 at 7:05pm
I think this is 3 wire. So how do I "bypass" that external reg?
I have the jumper going from power to the 'field' or regulator plug port. Should the second wire go straight to ground?
I tried all sorts of other configurations and couldn't get any charge.
KJCHRIS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KJCHRIS Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2026 at 7:23pm
That is a Delco DN series Alternator w a mechanical tack drive. mounted to it, not sure on the regulator.
  FYI; There are 2 Voltage Regulators that work with the DN alternators.
  1 for an Idiot light. AND 1 for an Ammeter. IF wrong Reg is used the Alt won't charge.
  Left wire (orange) on Alt is live at all times and goes on that left insulated terminal.
   FYI, I'd remove the short red wire.
Where you have red wire plugged in ("F" term) should be a wire (light green) plugged in, it comes from the #1, Left hand terminal on voltage regulator.
 The far-left wire on Alt is a ground wire.
 You should hear / or feel the regulator click in when the ignition switch is turned to the RUN position.
 Voltage Regulator terminals; left to right, must be grounded.
 #1 term on V Reg is wired to "F" field Term on Alt. Live when ign sw is in run.
 #2 term on V Reg is wired to ign sw terminal that is on in the run position. ign sw ON.
 #3 term on V Reg is wired to the Battery Cable stud on Starter Solenoid. Always live.
 #4 term on V Reg is not used.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2026 at 7:32pm
agree it looks like a DN alternator , so has an external reg.... look at the paper work and see if that is what you bought...
Post Options Post Options   Thanks (0) Thanks(0)   Quote MadCow Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2026 at 7:43pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote MadCow Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2026 at 7:45pm
Do you know which reg for ammeter I need? I would think the reg that was on it was right?
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2026 at 7:47pm
well since it says "replaces original"... i would guess they assume your using the external regulator.... couple drawings related to what Chris said....
Post Options Post Options   Thanks (0) Thanks(0)   Quote MadCow Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2026 at 8:02pm
Ok. Wired like this.
The big wire goes to ammeter.
The "F" green wire is original wire harness and connects to the "1" post on Vreg. I've tried in both plugs, there is no marking which is 1 or F. Left it as shown in picture, left plug. The wire is good, makes noise when connecting the meter to both ends.
VReg body is grounded, there is a strap connecting the body to the mounting post and I meter verified it is grounded. There is a spade terminal that isn't connected to anything that is NOT one of the front 4, it's on the side of the VReg, does that need to be grounded separate?
Wire "2" on Vreg goes to the ignition switch. I have a push pull two position switch. It's connected to the open side and connects to 12+ when switch is closed and ignition on.
Pole 3 at Vreg is 12+ always, connected to starter solenoid.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MadCow Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2026 at 8:06pm
There is no clicking and the VReg doesn't do anything switch on or off, engine running or not, bad solenoid coil in the reg?
The third wire, that little post on the Alt. Whether I plug that boot in or not doesn't change anything.
When I switch lights on I drop to 11.8v, and ammeter shows draw. Lights off I'm back to 12.3v but NO charge.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MadCow Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2026 at 8:07pm
Also I have double verified that I get very few mohm resistance in all the wires from one end to the other. So I'm confidence it's not a bad wire that I'm using.
Jim.ME View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim.ME Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2026 at 8:36pm
That is a Delcotron (Delco's name for the alternators) model 10DN externally regulated alternator.
Looking at the back of the alternator, the F (field) terminal is the right spade.  The R (reference aka sensing) terminal is the left terminal.
You can test the 10DN alternator by using a jumper wire between the Battery terminal and the F terminal to apply power to it.  This will full field the alternator and it should give you full output power.  Don't run it long that way.
Do not ground the Field wire from the regulator as it supplies power to the alternator field and grounding it can damage the regulator.
If you are trying to use the old regulator, it may be bad.  1. Test the alternator output. 2. Use a test light or voltmeter to test for power from the regulator to the alternator's F terminal.  If the alternator test ok and you don't get power from the regulator, you need a new regulator.  Steve at B&B can confirm, but I believe there are some electronic ones now that might be a replacement for the old ones with mechanical points.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2026 at 8:57pm
THE EXTERNAL REG SHOULD CLICK WHEN ENERGIZED
TedN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TedN Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2026 at 10:41pm
Transpo makes a regulator called a star II that effectively turns the 10dn into a one wire alternator. It mounts to one of the case bolts and has four connections; the 12v positive and negative and the field plug. I used one for many years(33 if my math is correct) on my 190XT until the insulation on the wires degraded so much I began to worry about an electrical fire.
https://ebay.us/m/sAxHvL
Edit - I just looked a little closer at the link I posted. It is a 24v regulator, most of them are 12v but look before you buy.
I am not going to recommend one unless you are really stumped though because they always have a slight draw on the battery. I had to have a battery shutoff switch or it would die after a week or so.
When I changed it out I went back to running a regulator hooked into the original harness. The electronic unit I bought is also from Transpo.
https://a.co/d/03ztzofq
I am not saying that Transpo products are the best, just that I have used them and have had good service life with them.
I did run an extra ground to the side terminal on the regulator, but if I remember correctly it wasn't needed, but I put it in as I was wiring in an auxiliary power relay so I had the extra ground in the area anyway.
Ted
Edited by TedN - 05 Apr 2026 at 10:46pm
190XTD seriesIII, 190XTD seriesI, maroon belly 7000, 7045, 190XTD series??? project(or maybe parts)
Post Options Post Options   Thanks (0) Thanks(0)   Quote MadCow Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2026 at 9:19am
I'm gonna grab a new reg and give it a go, no clicking is a tell tale I think. Probably a bad solenoid.
Ted, is that Amazon link one you used and it still draws? Won't want to hassle with a battery disconnect on this tractor.
TedN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TedN Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2026 at 9:36am
The one from Amazon goes in place of the original, so it is shut off with the key switch, and doesn't draw the battery down. I put it on three years ago and it still works, so I'm happy with it.
Edit - you may want to consider adding the pigtail to your harness in case you ever change it again, the wires will be in the correct place.
https://ebay.us/m/qy4Azy
Ted
Edited by TedN - 06 Apr 2026 at 10:49am
Lynn Marshall View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2026 at 9:38pm
Weren't there some regulators being made that looked like the originals and had all of the proper terminal connections, but were totally electronic. They didn't use a coil with points or make the distinctive click when energized???
TedN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TedN Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2026 at 10:10pm
Yes, that is the Amazon link. I haven't had any problems with mine since I installed it.
Ted
JC-WI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2026 at 12:04pm
TedN, I had one of those on my D17 when changing it over to alternator.
After about 3 years it started doing goofy things, like leave it in the back shed, the tractor would be dead in a week, leave it behind the barn hooked to the manure spreader which was under the barn cleaner, it would be dead in 3 days, leave it anywhere else on the farm it would start after a month of sitting.
  Since the D17 did not have a Delco connector for the Delco regulator, I wired in a cheap electronic after market (for ford/autolite) regulator and that worked for years until the cheap cork gasket went bad and let water inside. I had bolted it to the frame rail under the alternator, not under the hood or fuel tank where it might have had better protection, but I put the next regulator in the system where the old generator regulator sat and been there ever-since. The Ford units have different connection when adapting to the 10DN, left post labeled I goes to ignition switch, second post from left is B+ post that goes to battery, third post used with idiot light. 4th post or the far right post is the field post and that goes to the F terminal on alternator.  Several tractors got the electronic units when the Delcotron regs went bad, but the transistorized units started showing up and have used them instead because I did not want to make seperate connector wires to fit between the Delco plug and the ford regulator connectors which are narrower than the delco units are.
  Here is a heavy unit, not Delco but a replacement for it, and seems to be heavy, not electronic.fairly cheap, but if you want the rubber mounts to isolate the vibrations, you will have to take the mount off your old regulator and attach it to this one. I bought one to put my old Bobcat that was not working but got old one fixed before this new one arrived so on the shelf it goes.  Price wasn't bad, 12.95 plus free shipping
D635 VOLTAGE REGULATOR 1119515 Direct OEM Replacement 515 512 519 D635 Chevy NOS
Madcow, did you clean the contactor points in regulator? Have 12 volts to the left hand coil. My old regulator mentioned above was a connector that wasn't making connection on terminal 3, Ended up soldering a better connector on.
 Gotta be careful not to ground stuff out that shouldn't be grounded or you let smoke out which you probably know that ain't good in electrics.
Your first pic with red wire from HOT post on alt to first post in alternator , that connector post is used only when you have an idiot light in the system.
If you had connected that red wire to the right hand connector, where you got the green wire, you would have made the alternator go into full power mode and if alternator was good, you would find the back end of alternator, specially the shaft area greatly magnetized.
 Can't imagine anyone would reverse those lugs inside to make the field terminal be in the wrong position... cuzz the rotor brush inside is connected straight to the right spade connector .
 Good luck getting the no charge issue solved.
Edited by JC-WI - 07 Apr 2026 at 12:14pm
TedN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TedN Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2026 at 12:33pm
I have also seen a Mopar regulator hooked to a 10dn, the neighbor that did it claimed it worked.
https://a.co/d/07qlrJIH
They are also available in electronic now.
https://a.co/d/0fjaaUPp
I haven't used that option myself, so I can't recommend it to anyone else. It does lookk simple.
Ted
Les Kerf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2026 at 1:06pm
Ted
Gonna be tough to beat that electronic unit for price.
Most any "B" circuit regulator can be made to work
Post Options Post Options   Thanks (0) Thanks(0)   Quote MadCow Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2026 at 5:07pm
Problem fixed on this. I think it was the regulator. The field pin ended up being the one farthest from the power terminal. It only gets to 14.4 volts, but the new reg is sealed so I can't open it to adjust. This alternator or new reg must be a lot better though, as before with all electronics on I was getting 15-30 amp drain. Now it twitches when I turn on the lights but stays at zero, or even charge even while idleing.
Gear box removed. Think I'm going to make a new one so that I can use the old D19 tachometer with ground speeds.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2026 at 7:55pm
Originally posted by MadCow MadCow wrote:
... It only gets to 14.4 volts, but the new reg is sealed so I can't open it to adjust...
Sweet! Smile
14.4 volts is perfect Thumbs Up
