7580 gages
TrentH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TrentH Quote  Post ReplyReply Direct Link To This Post Topic: 7580 gages
    Posted: 01 Apr 2026 at 4:38pm
I have a 7580 that the temp and fuel gauge are all over the place when the tractor is running and when you turn the lights on the tac bogs down I’ve cleaned the main ground cable and no difference in how they act, the other odd thing is that after I cleaned the ground cable the self test of the warning lights worked for 5 seconds and quit but it still will start with the button. Any help is greatly appreciated.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2026 at 6:10pm
Start by unplugging the two harness connections straight ahead of the brake pedals, in the engine bay. Spray WD40 all over the prongs and re-connect them back together fully. Inspect for rust/corrosion or any wiring issues in that area.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TrentH Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2026 at 6:43pm
Alright I’ll have to pull those when I split it to do the power director anyway so hopefully that’s the problem.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2026 at 6:59pm
Sometimes when I have those connections separated, I will take a needle nose pliers and twist each male spade just a bit so they fit tight when you re-couple them.
This page was generated in 0.422 seconds.
