AC 170 175 PTO gear cover?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Topic: AC 170 175 PTO gear cover?
    Posted: 31 Mar 2026 at 10:01pm
What was the reason for the change of PTO gear cover change? The tube to cover just ahead of it? Just wondering? Tracy
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 31 Mar 2026 at 11:13pm
Sometime after the change to the front hydraulic pump, the internal lube pump for the power director clutch was eliminated and the power steering return oil was used instead to lubricate it. This required a way to keep oil levels between the two compartments level, so this tube was added.
Edited by DrAllis - 01 Apr 2026 at 8:31am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2026 at 9:44am
Dr Allis, thanks for the info. Learn something new every day! Tracy
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2026 at 9:48am
It was a good design change. It was cheaper to build (elimination of one pump) and function wise just as good.
Kevin in WA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kevin in WA Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2026 at 10:14am
Eliminating power director lube pump might have made sense but putting the main pump up front was a huge step backward in my opinion, cost savings could not have been that much
tbran View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2026 at 4:50pm
The highly machined bevel gear with machined splines was expensive - then throw in the bearings and assembly time and it saved over $200 / tractor. PLUS going to hydrostatic steering vs the mechanical assist and elimination of those gears and assembly time resulted in about a $500 reduction in cost.  approx $500 x 2500 units =  about   a mil  and a quarter saved.   Anyone who shaved a hundred bucks off a tractor was a hero !
