Plow parts 2000monoframe |
Buddy2366
Topic: Plow parts 2000monoframePosted: 11 hours 45 minutes ago at 7:27pm |
I am parting out a 2000 series model 2563 5-16's. It is 32" clearance.
(5) Used -392 moldboards #579746-$100.00 each (5) Used Frogs #567326-$50.00 each (1) Used Gauge Wheel Asy -No Tire #349289-$100.00 (1) Used Frame drilled for 16" cut #57403- $300 (1) Used Rear Lift Asy with 6 bolt tire/rim-$200 (4) Used Single Arm Rubber Mounted Coulters Asy-$100 each (5) Used Spring Trip stub beams-32" clearance -$50.00 each All parts picked up at my residence, Kansas, IL 61933 |
