Another CA Pickup Plow Spacer Question |
dfwallis
Topic: Another CA Pickup Plow Spacer QuestionPosted: 10 hours 16 minutes ago at 12:38pm |
The pickup plow manual shows a spacer that goes on top of the rear end of the pull bar (spacer is missing). In the line drawing, it seems to show it side-on as a straight piece of U channel with no cutouts for the through bolt in the sides. However, in the image of the installation earlier in the manual, it appears to show the end view of the U channel as if it would need a cutout in the sides for the through bolt to go through (and presumably keep it from sliding out). Not finding a suitable sized U channel, I'll probably make something.Does anyone know the design/dimensions of this spacer? The max gap is almost exactly 5/16 inch so the web thickness would be 5/16 or less I assume. I could also install it side to side so that the bolt goes through the channel, but that's not how the plow image shows it.
1952 CA13092
