I 40 swing ram adjustment
pineyjd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote pineyjd Quote  Post ReplyReply Direct Link To This Post Topic: I 40 swing ram adjustment
    Posted: 19 Nov 2010 at 4:18am
I took hoe off for painting & noticed threaded flange connection for cyld swing had threads showing more on one side,it looked as if the thresds backed out from use,as they had differ color.
Flanges have been welded,so I cannot take off & screw in shaft,is it possable to turn shaft to screw back into flange fitting with a web wrench ??
easygoin4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote easygoin4 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Nov 2010 at 7:05am
I too have an I-40 that has plenty of slop in the swing.
MY plan is to take off Hoe next year and look into it.
I did notice that I do not have the adjusting excentric cam on the top plate to adjust the gears for this like my manual indicates.
Looking forward to how yours comes out- take pictures if you can, I would love to get them from you as you do it via email.
Thanks
This page was generated in 0.365 seconds.
