1946 WC styled with Sherman trans
Darb210 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Darb210 Quote  Post ReplyReply Direct Link To This Post Topic: 1946 WC styled with Sherman trans
    Posted: 22 hours 38 minutes ago at 2:24pm
just got a wc with sherman unit, been sitting a long time, one owner until last week, is the sherman desireable? Im seeing prices all over the place just want some guidance.  Thanks!
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 22 hours 11 minutes ago at 2:51pm
is it  direct and over  or direct and under  or is it both ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Darb210 Quote  Post ReplyReply Direct Link To This Post Posted: 4 hours 17 minutes ago at 8:45am
how do i tell?
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 58 minutes ago at 12:04pm
put it in 4th gear, and if it runs about 9 mph you're in direct drive - shift Sherman again and if it flips you off the seat when you let off the clutch you have an overdrive. IF you let out on the clutch and you can read the letters on the tire - you have an under drive.
