Engine swap |
Paulb66
Topic: Engine swapPosted: 12 Mar 2026 at 10:26pm |
Will an engine from a 190xt diesel work in a 7020 and if so how many things would I have to change like oil pan etc. Thanks
DrAllis
Posted: 12 Mar 2026 at 10:37pm |
A 7020 chassis requires a 7020 engine backplate and probably the flywheel. Front engine plate mounting ears will not reach the side frames, so some fab work will need to be done there as the front plates will not interchange between engine fuel systems and front covers/oil pans, etc. XT oil pan and oil pump will work. Water pump lower hose is on the wrong side, and I think the fan centerline will be an inch lower. Some creative lower hose plumbing might solve that or a water pump from an F or G combine. If the XT engine fuel injection pump is actually set at 94 PTO HP you will have about 84 PTO HP in a 7020 chassis.
Edited by DrAllis - 12 Mar 2026 at 10:41pm |
Paulb66
Posted: 12 Mar 2026 at 10:56pm |
Thank you for all the information I Definetly don’t want to go to all that trouble I’ll either get this one rebuilt or wait for the right engine to turn up.
SteveM C/IL
Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8989 |
Posted: 13 Mar 2026 at 11:53am |
Fix the original and have something when done.
Lynn Marshall
Joined: 13 Sep 2009 Location: Dana, Iowa Points: 2484 |
Posted: 13 Mar 2026 at 6:47pm |
I would look for either a combine engine of the correct size or even a 426 from a 7040 or 7045 tractor. They can always be turned down if you don't need the power.
