B&S 22 hp VEE engine carb |
steve(ill)
Joined: 11 Sep 2009 Location: illinois Points: 90450 |
Topic: B&S 22 hp VEE engine carbPosted: 15 hours 20 minutes ago at 10:17pm |
have a 2005 Husqvarna 22 HP BRIGGS - 54 inch deck - 3speed HI/LO garden tractor that i have used a lot.. 21 year old and NEVER worked on the carb... Now it has a sputter / cough at anything below 1000 RPM... thought it might be the plugs, so i cleaned them - looked OK... thought it has 21 year old CARB, maybe needs a clean.. Took it apart ( double barrel) and all the gaskets and o-rings are BRITTLE !! .
Looked on line for a KIT and they are about $12.... Saw that you could buy a China CARB for $18. that fits 21- 22- 23- 24 - 25 HP engines... EVERRY VEE engine they ever built ?? HOw can that be ???.... Well, i bought a Chink carb for 2 chain saws, a weed eater and a leaf blower over the last 5 years and they are all GREAT... so i thought, WHY NOT, Only $18 bucks !!! Installed yesterday and fired it up.. RUNS GREAT !!.... Idle was about 1000 RPM so i dropped that a little with the idle screw.. other than that NO MODS NEEDED ! Read on line that the plastic manifold can warp and suck air and cause "bad idle"... mine was pretty much flat, but i put a thin layer of Permatex on it anyway ! I have had GREAT LUCK with this little China Carbs..
Edited by steve(ill) - 15 hours 18 minutes ago at 10:19pm |
jaybmiller
Joined: 12 Sep 2009 Location: Greensville,Ont Points: 25145 |
Posted: 7 hours 19 minutes ago at 6:18am |
GREAT, I 've also had GREAT success with those 'cheap china carbs' . Keep several on the shelf. Yes ago, Honda wanted $230+ for carb only, 9Hp. I swapped one off my 9HP 'offshore' engine. 1st pull, started and ran perfect. Since guy knew carb was $230, he was happy to pay me $300 to have his machine 'up and running'. Cost me $20 to replace the carb. What I don't understand is how Kubota can sell me a rear tire, on rim with valve , full of air for $340, yet the tire only is $500 !
steve(ill)
Posted: 4 hours 2 minutes ago at 9:35am |
well... like i sai... a box of 4 gaskets was $12.... but a MACHINED ALUMINUM carb with 14 different metal parts AND THE GASKETS was $18.... figure that out !
20 years ago that NIKKI double barrel carb was built in Japan... several years back they opened a manufacturing plant in China... i would BET that a NEW ENGINE comes with the CHINA CARB.. and the OEM sells them $18. CHINA CARBS for $250. Edited by steve(ill) - 3 hours 60 minutes ago at 9:37am |
Dave H
Joined: 11 Sep 2009 Location: Central IL Points: 3605 |
Posted: 3 hours 46 minutes ago at 9:51am |
Been my luck also with those carbs. Original one goes in the trash, new one from china goes on and you are off and to the races.
