Wheel weight bolts |
AC720Man
Joined: 10 Oct 2016 Location: Shenandoah, Va Points: 5429 |
Topic: Wheel weight boltsPosted: 3 hours 55 minutes ago at 1:48pm |
Looking for 70-223565, front wheel weight bolts for a D14. Need 6. If you have one but it’s not for sale please give me the measurements of it, I’m guessing I could use a carriage bolt and grind the side off to fit.
Thanks Robbie |
PaulB
Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 5259 |
Posted: 1 hour 29 minutes ago at 4:14pm |
I used square head bolts and did some "blacksmith" work on them. Heated the head and a bit of bolt up till red and then gave it a good whack on the anvil with a large chunk of metal on the bolt shank.
AC720Man
Posted: 52 minutes ago at 4:51pm |
I wish I had one to go by, I do remember the offset of the head. Could also just cut the side of it off but I need to know the size of the bolt and length. Maybe dad’s D15 SII bolt would be the same? I will look it up on Agco parts-book. His weights are on the inside. I think it has the offset as well.
